CEL 3, map sensor after swap
Old Sep 4, 2008 | 01:01 PM
k624ash's Avatar
Default CEL 3, map sensor after swap
I just finished swaping my gsr motor out of my teg into my civic, now i have a CEL #3 for map sensor. What could have cause this? since it was fine before. Do i need a new one?
Old Sep 4, 2008 | 07:52 PM
Endo-land's Avatar
What car do you have. If it originally came with the firewall map sensor on the civic that is the plug you need to use. Just tape back the one on the engine harness.
Old Sep 4, 2008 | 08:48 PM
k624ash's Avatar
Default Re: (Endo-land)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Endo-land &raquo;</TD></TR><TR><TD CLASS="quote">What car do you have. If it originally came with the firewall map sensor on the civic that is the plug you need to use. Just tape back the one on the engine harness.</TD></TR></TABLE>
ok, i think i do have the firewall one, its a 92 dx. So i use that one even though its for the gsr motor?
thanks ill try that tomorrow
Old Sep 5, 2008 | 06:28 AM
94EG8's Avatar
Seagull Management
Default Re: (k624ash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k624ash &raquo;</TD></TR><TR><TD CLASS="quote">ok, i think i do have the firewall one, its a 92 dx. So i use that one even though its for the gsr motor?</TD></TR></TABLE> You use the wiring for it, the connector that comes from the engine harness goes to the shock tower plug and then just stops.
illassek9
Jul 29, 2008 11:07 AM
schpiel
Jul 2, 2008 04:50 AM
dropd4door
Dec 28, 2004 03:57 AM
hatchinprogress
Nov 23, 2004 08:21 PM
buck02
Aug 31, 2003 12:51 AM
