Yikes!!! brakes ohh noez!!
Old Sep 4, 2008 | 12:36 PM
omarisramo's Avatar
Default Yikes!!! brakes ohh noez!!
Whats going on guys!? ok point of this thread is my problem with the brakes.
when i start my car, they get really soft and the breaks really dont work and its scarry.
and sometimes it will do that while driving!
and another thing is, does anyobdy know where i can get a EGR solenoid?
Old Sep 4, 2008 | 02:17 PM
Mr Yamada's Avatar
Default Re: Yikes!!! brakes ohh noez!! (omarisramo)
You can get parts such as BRAKE MASTER CYLINDER and EGR VALVE at this websight; http://www.hondaautomotiveparts.com/
But you'll need someone to help you find out WHAT YEAR Accord you have.
Old Sep 4, 2008 | 02:18 PM
omarisramo's Avatar
Default Re: Yikes!!! brakes ohh noez!! (Mr Yamada)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Yamada &raquo;</TD></TR><TR><TD CLASS="quote">You can get parts such as BRAKE MASTER CYLINDER and EGR VALVE at this websight; http://www.hondaautomotiveparts.com/
i apologize on that, its a 95 accord lx with a H22a in it.
so do u think its the master cylinder?
Old Sep 4, 2008 | 03:46 PM
erk89's Avatar
If you're losing brake pressure then it probably is your master cylinder, and yes it is scary. i got my master cylinder at O reilly autoparts, same with my EGR valve a year or so back
Old Sep 5, 2008 | 05:20 AM
TouringAccord's Avatar
H-T Order of Merit
when sitting at a stop can you pump the brakes a couple times and build pressure? While moving, when pressing the brake pedal does it lose pressure right away? Have you looked over everything to see if you have a leak?
Old Sep 5, 2008 | 05:36 AM
omarisramo's Avatar
Default Re: Yikes!!! brakes ohh noez!! (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">when sitting at a stop can you pump the brakes a couple times and build pressure? While moving, when pressing the brake pedal does it lose pressure right away? Have you looked over everything to see if you have a leak?</TD></TR></TABLE>
when at a stop, i can pump it a few times before it starts to build pressure, then it will work fine for a longer period of time, then agian it will loose pressure.
and for a leak, i did notice some weird fluid on my wheels, there was a small amount though
jofat91
May 14, 2011 10:40 PM
uses0ap
Oct 21, 2008 11:22 AM
zccrx
Sep 9, 2005 07:53 AM
oMek
Nov 5, 2003 02:26 PM
ophdehEEzY
Sep 5, 2003 02:04 PM
