99 coupe main relay problem, help pls
Old Sep 4, 2008 | 10:48 AM
yeding's Avatar
Default 99 coupe main relay problem, help pls
My car did not start this morning, so I was trying to take the main relay out. But I was so stupid not to remove the battery cable first. When I took inside part of the relay out, some metal legs touched, I saw a spark, after that, my car still crank but not start, and my CEL was not coming on when I first turn the key to "on".
did I mess up something other than the relay?? thx (all other light in the odometer area are functioning properly, and I checked my fule pump fuse which is fine).
BTW, any one know the part number of the main relay. I found it on rockauto.com 39400S84A01, but it said "not accord 2dr". main relays for 2dr and 4dr are not interchangable????
thx alot, guys
Modified by yeding at 6:30 PM 9/4/2008
Modified by yeding at 1:13 AM 9/5/2008
Old Sep 4, 2008 | 02:44 PM
yeding's Avatar
Default Re: 99 coupe main relay problem, help pls (yeding)
anyone can help?? I think I accidently shorted PIN 1-3.
Damn hurricane made me unable buy relay from part store and try out. thx. I'm quite frustrated now.
Old Sep 4, 2008 | 04:39 PM
dtapia's Avatar
you might have only damaged the relay.
Old Sep 5, 2008 | 11:21 AM
yeding's Avatar
Default Re: 99 coupe main relay problem, help pls (dtapia)
I changed my main relay. no luck...
I'm thinking about buying a used ECU on ebay, and have my mechanic put it on. is it a dealer only job??? thx a lot
Old Sep 5, 2008 | 12:50 PM
s13_240sx_92's Avatar
Check over all of your fuses, both under hood and under the dash board.
Old Sep 5, 2008 | 01:33 PM
yeding's Avatar
Default Re: 99 coupe main relay problem, help pls (s13_240sx_92)
yeeeeeees, cooooool
it turned out to be the ACG fuse. I checked all the ECU related fueses last night, but missed this one somehow. anyway, back on the road again!!!
thx guys.
BTW, what is "ACG" stand for??
tk_S2K
Feb 6, 2009 04:59 AM
ninjarich2
May 11, 2007 12:51 AM
DirtyBirdJR
Aug 29, 2005 02:59 PM
91d15bvtec
Jun 27, 2005 06:35 PM
