valve job on 89' civic D15 sohc non vtec
Not too difficult. You need to rotate the cylinder your working on to TDC and put air in the cylinder via air compressor so the valves don't drop. You most likely need piston rings instead of valve stem seals anyway.
blue_flames05
Suspension & Brakes
Sep 5, 2008 09:34 AM
jdm_racer831
Apr 4, 2007 08:49 PM
