Transmission & Drivetrain Gearboxes, Differentials, Clutches
which ring gear for ctr lsd in gsr trans
Old Sep 4, 2008 | 09:18 AM
1EG2NV's Avatar
Default which ring gear for ctr lsd in gsr trans
was going to install a civic type r lsd in my gsr tranny. Can I reuse the gsr ring gear when i swap the diffs? Also, what other mods. are needed if any to install the ctr lsd in the gsr trans? Thanks
Old Sep 4, 2008 | 10:50 AM
MFactory's Avatar
The EK9 LSD is the same as the ITR LSD, so yes, it will fit your GSR
Old Sep 4, 2008 | 12:09 PM
1EG2NV's Avatar
Default Re: (MFactory)
thank you sir, any other mods i have to do to put the diff in? I think i remember someone saying that i have to trim or shave something?!?
Old Sep 4, 2008 | 01:56 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (1EG2NV)
measure the clearance between the diff carrier bearings and the case...aka, diff bearing pre-load.
Old Sep 4, 2008 | 02:53 PM
1EG2NV's Avatar
Default Re: (Evs-One)
what should the clearance be?
turboek1
Jun 16, 2013 04:38 PM
V8whaaa
Jul 24, 2006 02:15 PM
goldbrick
Dec 15, 2003 04:29 PM
blakacintegera
Jul 13, 2003 03:37 PM
