94 Del sol starting problem
Old Sep 4, 2008 | 07:32 AM
Scooter_23's Avatar
Default 94 Del sol starting problem
ok first off my car was running fine until Sears aligned it and balanced the two front tires... i know thats crazy but its what happened...
B18B turbo'd LS
SaFc / pharable.com Ecu
dsm 440's
msd
The fuel pump is kicking on and car is getting spark
No power to the SAFC it doesnt come on... im guessing the ecu isnt getting power either.... check the ECU fuse under the hood and the main relay is clicking...
Anyone with any ideas or had this happen to them?
Old Sep 4, 2008 | 08:50 AM
Scooter_23's Avatar
Default Re: 94 Del sol starting problem (Scooter_23)
TTT
Old Sep 4, 2008 | 10:01 AM
obuhmyuh's Avatar
go over all your wiring and all your grounds, and make sure your battery has juice.
Old Sep 4, 2008 | 11:05 AM
Scooter_23's Avatar
Default Re: 94 Del sol starting problem (obuhmyuh)
battery has 12.30 volts, as far as the wiring im looking for a ecu wiring diagram now
Old Sep 4, 2008 | 02:15 PM
Scooter_23's Avatar
ok found the problem with my multimeter today.... turned out to be the SAFC was unplugged inside itself...... easy fix...
Old Sep 4, 2008 | 02:19 PM
obuhmyuh's Avatar
Default Re: (Scooter_23)
Sears did that?
Hondadaturbo
Sep 17, 2013 03:40 PM
sgnlab
May 28, 2012 08:26 PM
QuadJunky
May 12, 2012 01:17 PM
Maverick5189
Nov 17, 2009 06:05 PM
bigdogadam
Jul 21, 2006 11:11 AM
