H22 Crank
Old Sep 4, 2008 | 06:52 AM
Nosboost18's Avatar
Default H22 Crank
Can a crank from A USDM H22 be used inside a JDM H22?
Old Sep 4, 2008 | 09:17 AM
Rosko's Avatar
Default Re: H22 Crank (Nosboost18)
what year to what year?
Old Sep 4, 2008 | 11:24 AM
Nosboost18's Avatar
Default Re: H22 Crank (Rosko)
to tell you the truth i dont know the year on the JDM.
Old Sep 4, 2008 | 11:28 AM
twinksack's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nosboost18 &raquo;</TD></TR><TR><TD CLASS="quote">to tell you the truth i dont know the year on the JDM.</TD></TR></TABLE>
then no one can answer some came 55mm and some came 50 mm mains
Old Sep 4, 2008 | 11:40 AM
Nosboost18's Avatar
Default Re: H22 Crank (twinksack)
so i guess just measure the mains?
Old Sep 4, 2008 | 12:23 PM
REDLUDE4WS's Avatar
could you not figure it out from the serial number underneath the h22a tag. i don't know i've never tried? just wondering to try to help this guy out, ripping a motor apart to measure mains seems a bit much
Old Sep 4, 2008 | 12:28 PM
vinuneuro's Avatar
Any H22a1 (93-96) crank will work in a H22a. A USDM crank from a 97 H22a4 will also work.
Old Sep 4, 2008 | 01:14 PM
twinksack's Avatar
* B A N N E D *
Default Re: H22 Crank (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">Any H22a1 (93-96) crank will work in a H22a. A USDM crank from a 97 H22a4 will also work.</TD></TR></TABLE>
thats true but he dosent no the year
Old Sep 4, 2008 | 01:20 PM
vinuneuro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twinksack &raquo;</TD></TR><TR><TD CLASS="quote">
thats true but he dosent no the year</TD></TR></TABLE>
Apart from the Type-S and EuroR, all the jdm longblocks imported have been/are the obd1/closed-deck/50mm engine.
Old Sep 4, 2008 | 02:00 PM
Nosboost18's Avatar
Default Re: H22 Crank (REDLUDE4WS)
what would i look at under the h22 tag?
Old Sep 4, 2008 | 02:40 PM
Televator's Avatar
Apart from the Type-S and EuroR, all the jdm longblocks imported have been/are the obd1/closed-deck/50mm engine.</TD></TR></TABLE>
Really?! The JDM black tops are all closed regardless of year? I've only seen blue and red top H motors (which were all open). It was easy to think the rest of the regulars of that era were the same. I can't find much in searching or the FAQ....except the part that just plain says "H22A = closed deck", but I always thought that was a small oversight.
Old Sep 4, 2008 | 02:44 PM
vinuneuro's Avatar
Default Re: H22 Crank (Televator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Televator &raquo;</TD></TR><TR><TD CLASS="quote">
Really?! The JDM black tops are all closed regardless of year? I've only seen blue and red top H motors (which were all open). It was easy to think the rest of the regulars of that era were the same. I can't find much in searching or the FAQ....except the part that just plain says "H22A = closed deck", but I always thought that was a small oversight. </TD></TR></TABLE>
Nah, the H22a's are not all closed, but all the longblocks imported to the US are 91-96. You won't find a single obd2/open-deck regular (non Type-S/EuroR) JDM H22 in the states.
Old Sep 4, 2008 | 02:49 PM
Televator's Avatar
Ah, so they do change open/closed by year then. It's just that all the imports are closed...wierd. LOL
Old Sep 4, 2008 | 02:50 PM
Rosko's Avatar
Nah, the H22a's are not all closed, but all the longblocks imported to the US are 91-96. You won't find a single obd2/open-deck regular (non Type-S/EuroR) JDM H22 in the states.</TD></TR></TABLE>
Why is that btw? Just curious
Old Sep 4, 2008 | 03:13 PM
vinuneuro's Avatar
Absolutely no idea.
Old Sep 4, 2008 | 03:34 PM
dagle's Avatar
wait i thought the years included were 98 and before with the 55MM mains and the 99-01 were 60. cuz 99's when everything was updated right?
Old Sep 4, 2008 | 03:37 PM
street_accord94's Avatar
Default Re: H22 Crank (dagle)
93-97= 50mm
98+= 55mm
Old Sep 4, 2008 | 03:46 PM
Rosko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dagle &raquo;</TD></TR><TR><TD CLASS="quote">wait i thought the years included were 98 and before with the 55MM mains and the 99-01 were 60. cuz 99's when everything was updated right?</TD></TR></TABLE>
WOW you are waay off!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_accord94 &raquo;</TD></TR><TR><TD CLASS="quote">93-97= 50mm
98+= 55mm</TD></TR></TABLE>
Also some very early 1998 Preludes still had leftover '97 blocks.
Old Sep 5, 2008 | 09:22 AM
Nosboost18's Avatar
i was told.too just ckeck the numbers stamped on the crank.and on the block when you remove the oil pan.
Old Sep 6, 2008 | 07:22 AM
Nosboost18's Avatar
hey guys,you all are giving info about the JDM closed deck.my problem is CRANK.
Old Sep 6, 2008 | 09:33 AM
vinuneuro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nosboost18 &raquo;</TD></TR><TR><TD CLASS="quote">hey guys,you all are giving info about the JDM closed deck.my problem is CRANK.</TD></TR></TABLE>
Old Sep 6, 2008 | 09:50 AM
last time i checked, the main journal dimension also dealt with the crankshaft.
jdm, closed deck, etc. do not matter...it's the crank's main journal dimension that control its compatibility.
Chynito_JDM
Feb 14, 2005 01:08 AM
jayisnameless
Feb 7, 2004 09:25 PM
meanEG
Nov 29, 2003 09:46 PM
