cy-vmd9000u button removal
Old Sep 4, 2008 | 05:29 AM
Ricey McRicerton's Avatar
Default cy-vmd9000u button removal
I've been using this radio for years:
http://products.howstuffworks....w.htm
The rocker switch for the volume up/down is sticking on the down side. I've popped the black peice out of the middle trying to figure out how to "un-stick" this without breaking the button or the radio. Anybody have any experience with this unit?
Old Sep 4, 2008 | 02:50 PM
fcm's Avatar
fcm
Old Fart
Default Re: cy-vmd9000u button removal (Ricey McRicerton)
The "face plate" will have to be removed from the HU, it will be connected to the HUs "guts" with a multi-wire ribbon lead that will unplug at at least one end.
You will then have to remove the circuit board from the face plate, careful there may be "loose" parts.
Once the circuit board is removed you will have access to the buttons and switches, if it is a surface mount switch, [small push button switch mounted to the circuit board] you may find it is "collapsed" and unfixable and will have to be replaces, if it is just the plastic "rocker switch" in the face plate, you should be able to remove and clean it up. 94
Old Sep 4, 2008 | 05:37 PM
Default Re: cy-vmd9000u button removal (fcm)
Damn man, thanks a bunch.
I'm going to pull it out, pull the face plate off and try to remove the button. If it's more broken than that, it may be going to a repair shop. I suck at soldering and electrical work.
danomatic93
52
Nov 16, 2018 02:53 PM
EgHatchy96
Jul 7, 2013 12:09 PM
b20quang
May 23, 2008 05:58 PM
eg_junior
Jan 5, 2007 12:43 AM
