Are clutch internals interchangeable between different manufacture?
Old Sep 3, 2008 | 08:49 PM
itr1244's Avatar
Default Are clutch internals interchangeable between different manufacture?
in my case...
i have exedy clutch + FIDANZA flywheel.. and if the clutch disk is bad on this set up can i get competition clutch disk and use the rest ??
or do i need to get a new set?3
thanks
more info.. the EXEDY Organic Clutch is what i have..
i'm looking into competition stage 4 (disk) to replace exedy one?
Modified by itr1244 at 1:04 AM 9/4/2008
Old Sep 3, 2008 | 09:44 PM
vinuneuro's Avatar
Default Re: Are clutch internals interchangeable between different manufacture? (itr1244)
For the most part you can swap discs as the thickness is pretty much standard. However, I doubt that pressure plate from the organic clutch has the clamping force required for the disc you plan to use.
Read every post in here by Master of the Universe (skip the rest). It won't take that long. You'll definitely find a certain answer to your question (and more), as I read that thread last week.
https://honda-tech.com/zerothread?id=215379
chrisfromsrq
Dec 27, 2009 05:08 PM
snowblind7x
Feb 12, 2006 01:11 PM
hondacivic_si
26
Mar 2, 2005 07:20 PM
JDMorgan
Jul 5, 2004 09:00 PM
See Are X
Dec 28, 2002 08:46 AM
