Need install info on Apexi turbo timer in a 94Si... did search already
I'm looking for a turbo timer and I'm really interested in the Apexi auto timer. I've downloaded the instructions and it looks like they call for a "harness" that is specifc to the car. I'm sure if I knew what the wires were that are in the harnes I could tap my lines on the ignition.
Has anybody installed this unit with sucess? I like the idea of the "theoretical" A/F readout function since I'm boostin but A/F meters aren't worth their cost. It'd be nice to have one but not have to dedicate precious dash space to a real guage.
Thanks
Thanks
i got one on my car...we didn't use the harness though, we jus spliced the wires cause the harness is extra money.
So it's obvious what wires you need to splice into on the ignition? I am just a little concerned becasue the Apex instructions don't call out what those wires are. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by glagola1 »</TD></TR><TR><TD CLASS="quote">So it's obvious what wires you need to splice into on the ignition? I am just a little concerned becasue the Apex instructions don't call out what those wires are. Thanks.</TD></TR></TABLE>
Can anyone tell me where to find the wires I need (ie: wire x taps into wire z).
i too had that problem, what i did was just take off the cover under the steering wheel, where all the thick *** wires are at. i think its like 5 of them. i conected to a white one i think, a black one with yellow line and a yellow one with black line. it worked purrrrfect
PA MATT
Nov 9, 2004 04:13 PM
