Help code 16= fuel injectors
My friend has a 96 acura integra ls auto. I checked his car and found that he has a code 16 which is the fuel injectors. I was wondering how I should solve this problem? Replace the injectors or main relay? Anything I have have to test out??
you should make sure that the injector clips are all on tight. check the wiring on the injectors
i have inline resistors w/ 450 and one of the solder came off threw a cel and it was code 16
