i dont understand
Old Sep 3, 2008 | 04:50 PM
thebleek's Avatar
Default i dont understand
okay, here is my issue
i have a 00 y8 motor, it was swapped into my dx hatch.
the head had some crazy tapping issues so i swapped a y7 onto it. with a y8 manifold that was previously on my d16y7 motor. so it wont have any problems. except on the back there are 2 holes with 2 bolts it plugged it because i believe the y8 manifold i had was from a manual and not an auto. because the auto has them blocked off.
here is the problem. when i run the y8 ecu it will start the car but it idles all [freak]ed up...
when i swapped the y7 in there, without doing the iacv fix it wont start. it sounds like it wants to but wont. then i get an error code 14 [ics malfuntction??]
also when i had the y7 head on the y8 block still running the vtec cpu it would idle all [freak]ed up and be around like 100rpms lol.
all i did was change the oil, headgasket, and coolant. I dont understand what is going on. Can anyone help me? i had an old thread but i felt i needed to update, because its no longer how it was.
for reference here
https://honda-tech.com/zerothread?id=2378874 is the old thread. im about to kill myself here.
Old Sep 4, 2008 | 05:29 AM
Mr.Quang's Avatar
Default Re: i dont understand (thebleek)
From what you are saying is that you have a Y8 block with a Y7 non-VTEC head and a Y8 manual intake manifold.
When using a Y8 ECU (P2P), you must use a 2-Wire IACV with a 2-Wire connector and do the following IACV fix:
for 96-98 OBD2a
http://www.ff-squad.com/tech/w...8.jpg
http://www.ff-squad.com/tech/w...g.jpg
99-00 OBD2b
http://www.ff-squad.com/tech/w...1.jpg
I would not recommend using this ECU since it will not right correctly and will give you CEL's for malfunctioning VTEC
When using a Y7 ECU (P2E) you must use your Y7 throttle body with the 3-wire IACV. Also, you must use your Y7 throttle body gasket or it will never idle right.
You most likely have to adjust the Idle screw aswell, which is a fairly large flat head screw on the throttle body.
Old Sep 4, 2008 | 01:45 PM
thebleek's Avatar
Default Re: i dont understand (Mr.Quang)
im using the p2e and the 3 wire iacv
would i really need to adjust the idle? i thought you werent supossed to be able to do that on my motor [96-98]
but since all your other posts have helped me ill give it a shot after i get my timing right.
Old Sep 4, 2008 | 05:59 PM
Mr.Quang's Avatar
When I swapped a Y8 manifold onto my Y7 motor, my idle was way too low. It almost did not want to stay running at idle. It was sitting around 200 or below until I adjusted the idle screw out.
Old Sep 4, 2008 | 06:20 PM
thebleek's Avatar
holy **** thats kinda whats happening to me.
but i hear a tapping noise now. did u get that?
Old Sep 4, 2008 | 06:55 PM
twinksack's Avatar
* B A N N E D *
why did you swap the head why didnt you just adjust the valves
Old Sep 4, 2008 | 06:57 PM
thebleek's Avatar
Default Re: i dont understand (twinksack)
tried to, they still made the tapping noise
Old Sep 5, 2008 | 07:52 AM
LastGenEK's Avatar
I thought sohc's had loud valve tap and that was normal?
My D16y8 was pretty loud ( i miss that motor should of never sold it)
Old Sep 5, 2008 | 10:10 AM
thebleek's Avatar
not as loud as my **** is
renelovesnike
May 11, 2009 08:58 PM
SilverDEj6
Jan 30, 2009 03:56 PM
thebleek
Sep 3, 2008 05:31 PM
SOHC_civic_si
May 4, 2008 08:50 PM
TheAutoboxer
Apr 26, 2003 03:21 PM
