Quick question about sanding
Old Sep 3, 2008 | 01:08 PM
EvenStar's Avatar
Default Quick question about sanding
ok thats weird, i let it out to dry for about 30 mins after 3 coats of primer, sanded it down with 2000 grit, and now it kind of looks like the same as it did before but with just light scuff lines, is that correct?
why cant i just primer it again then spray the black color on?
Modified by EvenStar at 7:33 PM 9/3/2008
Old Sep 3, 2008 | 01:09 PM
Mike Ockhurts's Avatar
Default Re: Quick question about sanding (EvenStar)
whole thing
Evs-One's Avatar
Solbros Owns Me
if it's going to be painted, yes, the whole thing will need to be sanded eventually...whether with a scuff pad or some 320, etc
Old Sep 3, 2008 | 01:10 PM
-Gary-'s Avatar
Default Re: Quick question about sanding (Mike Ockhurts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike Ockhurts &raquo;</TD></TR><TR><TD CLASS="quote">whole thing</TD></TR></TABLE>
whole thing = paint stick to all
Old Sep 3, 2008 | 01:11 PM
EvenStar's Avatar
so how am i suppose to know when the sanding job is ready for primer?
sorry this is my first time
Old Sep 3, 2008 | 01:15 PM
Honda Tool's Avatar
2010 Honda-Tech Poker champion
Default Re: (EvenStar)
When the whole thing is dull or scuffed it is ready.
Old Sep 3, 2008 | 01:17 PM
EvenStar's Avatar
Default Re: (Honda Tool)
alright, so after that apply 2-3 coats of primer, then sand it down again with whatever grit i have correct? then apply the color spray?
Old Sep 3, 2008 | 01:18 PM
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvenStar &raquo;</TD></TR><TR><TD CLASS="quote">alright, so after that apply 2-3 coats of primer, then sand it down again with whatever grit i have correct? then apply the color spray?</TD></TR></TABLE>
seriously??? Watch a youtube video on painting or pay someone to do it
Old Sep 3, 2008 | 01:20 PM
Honda Tool's Avatar
scuff it again after primer yes.
Old Sep 3, 2008 | 01:22 PM
-Gary-'s Avatar
Default Re: (Evs-One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">
seriously??? Watch a youtube video on painting or pay someone to do it</TD></TR></TABLE>
Someone always has to respond like this at least once in a request thread @H-T.
Old Sep 3, 2008 | 01:28 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (-Gary-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gary- &raquo;</TD></TR><TR><TD CLASS="quote">
Someone always has to respond like this at least once in a request thread @H-T.</TD></TR></TABLE>
Do you not realize how many hundreds of posts/links/pictures/videos there are of people painting parts??
I haven't been a member as long as most, but it gets tiring seeing the same threads pop up that could easily be avoided by a simple google search.
Old Sep 3, 2008 | 02:02 PM
saywhat's Avatar
I would recommend Wet-sanding with 400 before primer.
Old Sep 3, 2008 | 06:32 PM
EvenStar's Avatar
Old Sep 3, 2008 | 06:40 PM
Rock Meathammer's Avatar
What are you painting?
Old Sep 3, 2008 | 06:43 PM
EvenStar's Avatar
Default Re: (Rock Meathammer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rock Meathammer &raquo;</TD></TR><TR><TD CLASS="quote">What are you painting?
my OEM lip kit
i remember my friend sprayed his car down with primer, sanded it down, primed it again, and applied the color coat on top. ill assume that the material is just different since lip kits are plastic.
Old Sep 3, 2008 | 10:10 PM
smileycvc's Avatar
Default Re: (solbrothers)
spray the primer and sand it with some fine grit paper. When you run your hand over it, it should feel smooth. When the entire part is smooth, but there is still and even layer of primer you are good to go. If you spray primer and run your hand over it after it dries it should feel kind of rough. You dont want that and that's why you sand it smooth.
Old Sep 3, 2008 | 10:14 PM
Patrick's Avatar
You need 50 grit!
Old Sep 3, 2008 | 10:23 PM
UCLA.lion's Avatar
I <3 My CB7.
Default Re: Quick question about sanding (Patrick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patrick &raquo;</TD></TR><TR><TD CLASS="quote">You need 50 grit! </TD></TR></TABLE>
dont they use that grit on the top of skateboards.
Old Sep 3, 2008 | 10:41 PM
Leo C's Avatar
Night Owl
Default Re: Quick question about sanding (UCLA.lion)
200-300 grit is what you need for this stage, not 2000.
Reported for a move to paint/body for more knowledgeable answers.
Old Sep 3, 2008 | 10:43 PM
EvenStar's Avatar
Default Re: Quick question about sanding (Leo C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leo C &raquo;</TD></TR><TR><TD CLASS="quote">200-300 grit is what you need for this stage, not 2000.
Reported for a move to paint/body for more knowledgeable answers.</TD></TR></TABLE>
sorry about that, i needed quick replies thats why.
anyways, finally finished them.. cant wait to put on the top clear coat
Old Sep 5, 2008 | 11:24 PM
Eyger's Avatar
I think you need to follow the manufacturers instructions when preparing a surface for basecoat.
As for getting a surface ready for primer, you should.....follow the manufacturers tech sheet. it's got all the answers right there.
As for getting a surface flat.... you can use 120, 220, then wet 300 or 400.
Anything else higher, you're pretty much wasting your time, because it won't be rough enough to block down the imperfections.
sk8shorty012
Oct 10, 2007 07:34 PM
LeArN2LiVe
Paint and Body
Jun 27, 2007 01:32 PM
DCnotTHEshoes
Honda Motorcycles
Jun 4, 2007 07:35 PM
lamboextreme
Feb 5, 2007 09:51 PM
InfamousRS
Jul 19, 2003 10:55 PM
