Rattling/Noise comming from GSR Transmission
[freak] i was hoping it wan't the input shaft bearing. The car isnt on the road yet and has no oil in the tranny yet. so im thinking since there is no fulid in tranny it is making it a ahell of alot louder than it should be.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dang EG »</TD></TR><TR><TD CLASS="quote">
I would be very concerned that there is no oil no matter what. You should really try it with oil and go from there. </TD></TR></TABLE>
--- I was under the impression that it didn't even matter. As long as you weren't shifting or leaving it in gear. I guess i will pop some oil in that tranny and do it all over again. See the outcome.
I would be very concerned that there is no oil no matter what. You should really try it with oil and go from there. </TD></TR></TABLE>--- I was under the impression that it didn't even matter. As long as you weren't shifting or leaving it in gear. I guess i will pop some oil in that tranny and do it all over again. See the outcome.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">I assume you started the motor without oil as well?????
Not very smart.</TD></TR></TABLE>
--- Why would you even think that? That wasn't implied anywhere in what i said. The car is on jack stands, and isn't road ready. I just put the motor in so i filled all the fluids and checked to see if motor ran. Didn't put anything in tranny because all i had was synthetic oil and i wasn't driving it nor doing anything with the transmission.
EDIT:
That video you see there is of my old car with the same transmission. That was when i had a rs with gsr tranny. That was in running order and had that sound. It isn't how the vehicle is now. If that's what you were going by.
EDIT:
SJR
Apr 21, 2005 06:56 PM
