got new camshafts in wired idle issues.
Old Sep 3, 2008 | 12:06 AM
BKKloppenborg's Avatar
Default got new camshafts in wired idle issues.
hey guys just got my Brian Crower Stage 2 camshafts in the car. However when i idle it goes up to 900-1,000 rpms and then jumps down to around 500-600 and feels like it almost dies. What could be causing this?
Somone said my Fuel injectors are probaly dirty and need to be cleaned, or they need to be upgraded to bigger ones with a new fuel pump. another person said its normal until i get it tuned. Another said that i need to adjust the fuel ratio, with a fuel regulator. Can you guys tell me what it is and some suggestings what i should do next to have it run in top condition. Thanks, Brian
Modified by BKKloppenborg at 1:17 AM 9/3/2008
Old Sep 3, 2008 | 12:26 AM
Spec R's Avatar
Default Re: got new camshafts in wired idle issues. (BKKloppenborg)
if you havent done anything to the car other than install the cams, the random idle issues are normal.
until something (stand alone ecu: hondata/aem/crome/neptune/uberdata etc OR piggyback system: vafc, field, vmanage etc) modifies the fuel and ignition maps at idle, then you're going to see idle fluctuations.
even then, you'll still see a little fluctuation.
Old Sep 3, 2008 | 12:14 PM
gsrteg08's Avatar
I suggest putting the stock cams back on, then when you ready and have done some serious work to the engine, slap them Stage 2 cams back on...
Old Sep 4, 2008 | 01:43 PM
styles671's Avatar
yups.. just wait til u do more to your motor and then slap on the cams
Old Sep 4, 2008 | 01:44 PM
styles671's Avatar
try getting cam gears also..
Old Sep 4, 2008 | 03:22 PM
Default Re: (gsrteg08)
Just paid to put them in, i can't pay to take them out now.
Idle issues were Spark plugs that were very fried.. Now idles fine. Still running lean though need a fuel regulator.
VNZ444
Engine Management and Tuning
Mar 30, 2016 09:05 AM
K20EF8Dx
Aug 25, 2010 08:35 PM
civictype-r
May 25, 2006 02:48 PM
BoostedD15B7
Nov 12, 2003 05:53 PM
White98LS
Jul 23, 2002 09:21 AM
