B16A obd2 help
Ok i got a 92 hatch with a z6 swap and im looking to get a b16a the obd2 one but need to convert it to obd1 so what all do i need just the ecu and obd1 distributer or is there more parts i would have to swap over??
alternator and injectors too, or just get a '96 - '01 USDM integra GS-R engine harness and you wont have to change anything provided your running a chipped P28
why does it need to be chipped? and do you know where i can get the gsr harness because i think that would be cheaper right instead of buying erything to make it obd1? thanks for the help by the way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrcvc93 »</TD></TR><TR><TD CLASS="quote">you don't need to run a chipped ecu but you will have to get a obd 1 gsr or p30 ecu or the easiest to find a p28 </TD></TR></TABLE>
The reason I put chipped P28 was so he would have to wire the knock sensor, although he could use a P30 and wire the knock sensor or a chipped P72.
so if it was obd2 is that the only other sensor i would need to wire if it wasnt chipped?? so if i had a chipped p28 and the obd harness is that all i would need to just drop it in?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SNooPY-JDM »</TD></TR><TR><TD CLASS="quote">so if i had a chipped p28 and the obd harness is that all i would need to just drop it in?</TD></TR></TABLE>
Yeah, thats the beauty of owning a '92 civic, that one year only vtec was prewired from the ECU to the shocktower plug. So yeah just plug in the GS-R harness and get a P28 chipped with B16A maps and you're good to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SNooPY-JDM »</TD></TR><TR><TD CLASS="quote">aight thanks alot that makes the process alot simpler lol one more question is there a good site to go on to get a gsr harness</TD></TR></TABLE>
Your kind of on your own for that one, Its hard to give recomendations since i live in canada and don't even really know where you would order from in the US, but you could possibly calling your local junkyards and see if they have one or if they can get one from another yard, also check the honda-tech marketplace.
stw88crx
Nov 10, 2004 01:24 AM
s2000june
Jun 18, 2004 10:19 AM
