NO START ISSUE, have fuel, spark to all 4...timing is good
94 GSR, new plugs, wires, dizzy. Checked for spark to all 4 cyl, and have fuel to all 4 cyl. Only 1 & 3 are hot on header after cranking, 2 & 4 are still cold.
Please help. Any ideas?
BTW, this is an all new motor, it has never ran. EVERYTHING is new/rebuilt.
GSR block/ B16 PnP head, S2S2 cams
Modified by 9t4fodo at 6:43 PM 9/2/2008
it should start. :S try removing spark plugs and add a little oil down the hole and give it some more cranking. gl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic »</TD></TR><TR><TD CLASS="quote">check your firing order there is a diagram on here somewhere, i would be willing to bet 2 and 4 are reversed on the dizzy </TD></TR></TABLE>
agreeeeeeeed
agreeeeeeeed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9t4fodo »</TD></TR><TR><TD CLASS="quote">Ok, i adjusted the valves and it fired right up. Now it just won't stay running and the timing belt is loose on the back side of the motor. How do i get it tight?
install it right
install it right
remove spark plugs -> loosen tensioner-> rotate crank by hand/wrench 5 or 6 rotations-> make sure everything is lining up->tighten tensioner->reinstall plugs-> rip mad vtak y0 ...lol
gl
gl
I have it running now. Have a check engine light for IACV...would that make it shudder while driving? I put a manual oil pressure gauge on it, and it's holding pressure just fine, although i had a light for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9t4fodo »</TD></TR><TR><TD CLASS="quote">I have it running now. Have a check engine light for IACV...would that make it shudder while driving? I put a manual oil pressure gauge on it, and it's holding pressure just fine, although i had a light for it.</TD></TR></TABLE>
Yup, did you forget the seal or maybe have a vacuum leak.
All motor...what seal are you talking about? As far as vacuum leaks...i don't know, but i'll check tomorrow, do you think it could be just a bad IACV?
BTW, how is your stroker motor holding up? This is mine finally in and running.
also FYI there is a common Main Relay issue on the Integra's, and most Honda's really. it's likely been documented here before, however i work at a Toyota/Honda dealer (parts) and recently had a very similar no-start issue myself. as i was instructed 'kick' the main relay (i found that tapping it with the handle of a screwdriver is just as adequate, and sounds a whole lot less abusive
) its located down by your clutch pedal under the kick panel, and the relay will get stuck closed after you get a few miles on the vehicle, tapping it opens the circuit up and allows the vehicle to start. as my tech instructed me, replace the relay as soon as you have this problem.
scotty.b16a1
Dec 31, 2012 01:54 PM
Honda Hick
Feb 28, 2005 09:20 AM
