changing distributor
Old Sep 2, 2008 | 04:49 PM
batallic's Avatar
Default changing distributor
how do i take it off,
any tips
Old Sep 2, 2008 | 04:52 PM
batallic's Avatar
Default Re: changing distributor (batallic)
im also changing the rotor too
Old Sep 3, 2008 | 02:18 AM
fuzzie's Avatar
i also need help with taking off the distributor cap and changing the rotor.
Old Sep 3, 2008 | 06:35 AM
DrewMD's Avatar
Davis Photography
Default Re: changing distributor (fuzzie)
the cap comes off with three small screws off the distributor. Just unscrew those, unplug the cables from the cap, and pull.
As for the actual dizzy, its held on my three 12mm bolts to the block. pull the plug off the clip then disconnect it. Remove the three bolts and pull after you remove the four plug wires from it. There will be a small oil leak coming from the block.
William1991b
Oct 9, 2011 07:44 PM
zairas
Oct 25, 2009 10:37 PM
polyhonda
Sep 5, 2008 01:50 PM
02z2899ex
11
Apr 22, 2005 12:09 PM
B18C_EJ8
Sep 4, 2003 08:04 AM
