Transmission & Drivetrain Gearboxes, Differentials, Clutches
clutch and flywheel
Old Sep 2, 2008 | 02:50 PM
95_red_dc's Avatar
Default clutch and flywheel
I am installing a new competition clutch stage 4 and a fidanza flywheel on my 95 gsr. I have the flywheel bolted up and I'm trying to get the pressure plate bolted up to the flywheel but the alignment pins wont go through the pressure plate hole.Has anyone had this problem? How do you know which way the 6 puck disk needs to face? What parts store carry the pressure plate bolts?
Old Sep 3, 2008 | 04:15 PM
Tarmac Junkie's Avatar
Default Re: clutch and flywheel (95_red_dc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_red_dc &raquo;</TD></TR><TR><TD CLASS="quote"> I have the flywheel bolted up and I'm trying to get the pressure plate bolted up to the flywheel but the alignment pins wont go through the pressure plate hole. </TD></TR></TABLE>
Are the pins lined up but they seem to be too short? If this is the case try flipping the disk around. The disk flat side should go to the flywheel, and the raised part should go to the presure plate side.
Old Sep 3, 2008 | 10:09 PM
Mista Bone's Avatar
D Tranny Guru
rotate the pressure plate 120 degrees either way .
Old Sep 4, 2008 | 05:49 PM
paton5g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_red_dc &raquo;</TD></TR><TR><TD CLASS="quote">What parts store carry the pressure plate bolts? </TD></TR></TABLE>
You'll have to order those from Honda. They're rated, with a Hex head. You won't find them anywhere. And they're cheap. Do not use unrated bolts.
Old Sep 4, 2008 | 08:58 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: clutch and flywheel (paton5g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paton5g &raquo;</TD></TR><TR><TD CLASS="quote">
You'll have to order those from Honda. They're rated, with a Hex head. You won't find them anywhere. And they're cheap. Do not use unrated bolts.</TD></TR></TABLE>
Not hex head, 12 point instead.
Old Sep 5, 2008 | 02:38 AM
paton5g's Avatar
Default Re: clutch and flywheel (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">
Not hex head, 12 point instead.</TD></TR></TABLE>
My apologies, they are 12 point.
dtme46
Mar 7, 2009 11:07 PM
95_red_dc
Sep 2, 2008 06:19 PM
boosted350z
Nov 27, 2004 06:49 AM
boosted350z
Nov 26, 2004 06:54 PM
luderone
Sep 13, 2003 02:01 PM
