90 CRX 1.5 DX died on the freeway and won't start
Old Sep 2, 2008 | 12:58 PM
honda_nooblet's Avatar
Default 90 CRX 1.5 DX died on the freeway and won't start
(Car is totally stock with 150k on it)
- Turns over fine--new battery
- Got gas squirting out of the fuel pump when I turn the key on with fuel line diconnected.
- Sprayed starter fluid into throttle body while cranking and it doesn't fire
- Got spark at the plugs
- Replaced distrib cap
- Rotor is tight--no play at all
- Timing belt looks fine and is tight
- All valves are working so camshaft is fine
I don't know what else to try. I don't have a timing light. It's throwing code 1 (O2 sensor) which has been bad all along. I borrowed an ODBII reader from a friend but I can't figure out where to plug it in. I thought it was right by the steering column.
Any advice would be appreciated. Thanks in advance.
Old Sep 2, 2008 | 01:47 PM
dylokjai's Avatar
Default Re: 90 CRX 1.5 DX died on the freeway and won't start (honda_nooblet)
Your car is not OBDII....
Old Sep 2, 2008 | 01:52 PM
Coltmorris's Avatar
Default Re: 90 CRX 1.5 DX died on the freeway and won't start (dylokjai)
Compression check?
Old Sep 2, 2008 | 01:53 PM
Maxcapacity's Avatar
Maybe your distributer itself is pooched.. got any friends that you can borrow one from?
Old Sep 3, 2008 | 06:30 AM
Default Re: 90 CRX 1.5 DX died on the freeway and won't start (Maxcapacity)
And the winner is...MaxCapacity. Rotor melted and spun on shaft.
Old Sep 3, 2008 | 08:29 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
That could be a sign of things to come..
When the bearing inside the distributor starts going bad,
It will produce a lot of excess heat..
Old Sep 3, 2008 | 04:31 PM
beige89civic's Avatar
* B A N N E D *
OBDII is 96 and newer for future reference.
tintinmilou
Aug 9, 2011 08:31 AM
andy24
Feb 13, 2011 02:16 PM
neoc03
Jan 2, 2010 10:26 PM
jaybees
15
Apr 6, 2005 04:30 PM
junya16
Mar 1, 2003 05:41 PM
