wheel offset
Old Sep 2, 2008 | 12:24 PM
Drew17th's Avatar
Default wheel offset
hey I have a 97 coupe and I'm ordering enkei rpf1's 15x7 4x100 and I need to specify offset! Can some1 explain what offsets would work and how that works with tire sizes? Thanks
Old Sep 2, 2008 | 04:21 PM
BlueIntegraBoy's Avatar
Default Re: wheel offset (Drew17th)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tire Rack &raquo;</TD></TR><TR><TD CLASS="quote">The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (measured in millimeters).*
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
For that wide of a rim, I would get an offset between +35-40. If you get a wider tire and buy a higher offset, you will rub on the inside of the fender well. If you get a too negative offset (less positive) and your car is low you will rub on your outer fender/quarter panel wells.
Old Sep 2, 2008 | 04:31 PM
alphalanos's Avatar
Offset doesnt affect tire size. rim width affects size. But yesh for example my slips are 15x7 +40 offset and I have 205 tires on it. They are about flush with my fenders. Actually had to roll them slightly.
Old Sep 2, 2008 | 07:54 PM
Drew17th's Avatar
Default Re: wheel offset (alphalanos)
i noticed alot of people are selling rpf1's and they seem to be +41 or +45 offset! does this sound right?
Old Sep 12, 2008 | 10:42 PM
Drew17th's Avatar
still trying to figure out the best offset that's good for my 96 coupe meant for occasional driving/autocross/road course! I wanna order my wheels but no good at offset
Old Sep 12, 2008 | 10:57 PM
FamousRacingInk's Avatar
i just got a set of 17x7 with a +40 offset and they fit just fine but my civic isnt lowered yet.
Old Sep 16, 2008 | 10:15 PM
Drew17th's Avatar
Default Re: (FamousRacingInk)
bump for offset
Old Sep 17, 2008 | 12:21 AM
naRIPSTA's Avatar
I am my avatar
Buy +45, call it a day.
Old Sep 17, 2008 | 09:50 PM
Drew17th's Avatar
Default Re: (naRIPSTA)
why ?
Old Sep 17, 2008 | 10:19 PM
naRIPSTA's Avatar
I am my avatar
Well, why not?
Old Sep 23, 2008 | 11:04 PM
Drew17th's Avatar
so im thing +35 offset, does this sound like it would be right for a 15x7 wheel on an ek coupe setup for daily with occasional autocross/roadrace?
Old Sep 24, 2008 | 12:31 PM
Drew17th's Avatar
bump
Old Sep 24, 2008 | 12:46 PM
scuzz's Avatar
My VSR 15X7 wheels are +40 and fit in my fenders of 95 hatch great.
Old Sep 24, 2008 | 03:28 PM
The Collin's Avatar
Drew17th, a +35 like you're thinking about getting will be just fine.
Old Sep 24, 2008 | 04:56 PM
Projekt Motorsports's Avatar
New User
Default Re: (99_hb_on_air)
you could always run a smaller tire which would allow the tire to stretch givin you more clearance if need be
F20Cdriver
Oct 13, 2008 08:16 PM
Ponyboy
Apr 15, 2007 12:39 PM
typeR564
Honda Fit
Jul 19, 2006 01:54 PM
torqueless
Jul 13, 2005 12:12 PM
gribbs
Jan 30, 2003 11:58 AM
