cv axle/driveshaft install??
x2
and or look up the articles on here and team integra
it's really not too bad. most the time the seperation from the mid shaft to your cv is the worst. stuck on many times if you have oe axles. easier to pull if you drop the mid shaft and seperate on the ground.
Next time, make sure you also search the Archive section.
Page 1 does not have pictures but Page 10 has pictures.
https://honda-tech.com/zerothread?id=382416&page=10
Got the job done. The trouble was separating the lower ball joint, it was a bitch because it was old and rusted. There was so much play in it, that It was difficult to separate.
raznkane
Nov 2, 2015 07:09 AM
kudos. those ball joints can be a PITA
