Problem with battery when the weather is cold
Old Sep 2, 2008 | 09:53 AM
Ruben19's Avatar
Default Problem with battery when the weather is cold
I have a 00 EM1 and i park it inside a garage.
I don't activate the alarm but when the weather is cold the car wont start.
Summer time i can leave the car inside the garage for weeks and he will start right up.
During the winter, i have to disconnect the battery so the car will be able to start next time.
What can i do.
I was thinking about buying a battery warmer or blanket
Old Sep 2, 2008 | 05:11 PM
Unit44justin's Avatar
did you try a new battery
Old Sep 2, 2008 | 06:01 PM
dohczccrx's Avatar
Default Re: (Unit44justin)
bingo^.....batterys are rated for volts and cca. the cold cranking amps are low you may have a dead cell. so i would replace the battery and be done
Old Sep 2, 2008 | 06:15 PM
dangthemang's Avatar
Default Re: (dohczccrx)
get a battery with higher cold cranking amps
Old Sep 2, 2008 | 09:28 PM
Ruben19's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unit44justin &raquo;</TD></TR><TR><TD CLASS="quote">did you try a new battery</TD></TR></TABLE>
Is not the battery
i had two batteries and they all did the same.
they both tested good.
Before i have a yellow optima battery but i dont think i have this problem with this battery. but the optima only lasted 1 year.
Old Sep 2, 2008 | 09:30 PM
Ruben19's Avatar
Default Re: (dangthemang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dangthemang &raquo;</TD></TR><TR><TD CLASS="quote">get a battery with higher cold cranking amps</TD></TR></TABLE>
Where can i find a battery with higher cold cranking amp. mine is 500cca but thats the highest cca battery you can find at the autoparts stores
Old Sep 2, 2008 | 10:50 PM
Since 1983's Avatar
optima=junk IMO......check online or talk to a guy at a parts store, try and get something with a higher cca rating
Old Sep 2, 2008 | 11:36 PM
Ruben19's Avatar
there aren't many choices on 51R series batteries.
A bigger battery wont fit in there.
Old Sep 2, 2008 | 11:38 PM
Ruben19's Avatar
im using Interstate battery now.
500CCA
before i had Autolite 450CCA( Im using this battery on my Hatch) still works
This problem only happens on my EM1
Old Sep 6, 2008 | 06:29 PM
Ruben19's Avatar
anyone else
Old Sep 6, 2008 | 09:40 PM
Frickr's Avatar
Default Re: (Ruben19)
a battery blanket might help, i have an autolite, and my car cranked over when it was 40 below last winter, and if your in a garage, you shouldnt have a problem.
one thing to check, is the water on the battery. if its not completely full, you can have problems starting.
Old Sep 11, 2008 | 07:12 PM
Ruben19's Avatar
thanks
i will check out the water level
BrianDobell
Honda Civic (2006 - 2015)
Jan 22, 2018 05:25 PM
dgdarien
Audio / Security / Video
Mar 15, 2017 07:04 PM
WTypeRogerX
Mar 18, 2003 01:11 AM
B18C-RnVA
Nov 7, 2002 04:44 PM
