1988 CRX HF race project
I have a ton of questions, and hope you guys can help. I searched of course but only have found limited info, hopefully someone here has done this swap...
Just picked up a 1988 crx HF
plan to put b18a or b motor in
Questions I have are as follows:
1. What parts are needed for swap besides (complete motor assembly, ECU, complete wiring, HASPORT mount kit)
I think i need knuckles/hubs from a 90-91 integra, but what else?
I think an LS tranny is the best bet for A/X and track use, but is there something better that you would recomend? I would hopefully like to buy the tranny with an LSD in it already. Also how do I get a B-series transmission to bolt into the older series tranny site (ie linkage and such)
Any websites, or places to gather this information would be great. I would like to start right in on this project but would like a good idea of what I need and how I should get it together before I start ripping it apart.
Thank you!
Thank you!
Guest
Posts: n/a
1. What parts are needed for swap besides (complete motor assembly, ECU, complete wiring, HASPORT mount kit) adjustable shift linkage w/ hcp mounts other wise 90-93 teg linkage should work w/ hasport. 90-93 teg axles and intermediate shaft. prolly non of your exhaust will bolt up properly. remember to take dust shields off of hubs
2. I think i need knuckles/hubs from a 90-91 integra not needed
3. think an LS tranny is the best bet for A/X and track use, but is there something better that you would recomend? y1s1
4. I would hopefully like to buy the tranny with an LSD in it already. i think the y1s1 does
5. Also how do I get a B-series transmission to bolt into the older series tranny site (ie linkage and such) see #1
Thank you!
http://www.hondaswap.com
do a b18b
[Modified by TorteX, 7:39 PM 7/24/2002]
Thank you!
do a b18b
http://www.hasport.com
you need to get si or dx knuckles.. all other answers are on the hasport website... very common knowledge.. just look around.
Andrew
Andrew
Hey T-Bone, long time no see.
Unfortunatley this weekend is the largest Rally in the US, and its in the home state of maine so I will be at that.
Im desperatley trying to find a good chassis, the 88 hf i was about to pick up today had so much rear 1/4 rust i just didnt want to deal with it
sneedles1
11
Nov 1, 2009 10:46 AM
P h i l
15
Apr 27, 2004 10:49 PM
