OEM 99-00 Raybrig HID plug and play
Yes, I have. It's a little time consuming. I had to drill a hole in the metal plate on the back of the fog to pass the HID wires through. Made it the correct size for the grommet included on the HID bulb to go into. Also had to cut some off of the metal frame that the fog mounts into so the adjustment range was good and the wires wouldn't get smashed or cut.
If you send me a pic of your fogs from the back side, I can make marks in paint to show you exactly what I did. I put the ballasts on the radiator support.
Ryan
Ryan
The back side where it was heat shrinked came right to the metal cover. Once the grommet is installed in the cover, it was fine. I had to cut the rear side of the bracket so I could run the wires without worrying about them getting cut. I'll be over there this weekend and I'll get you some pics.
Ryan
Ryan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by just_dung »</TD></TR><TR><TD CLASS="quote">Are you referring to the usdm integra fog lights? I'm gonna search for it now. Thanks for the info.</TD></TR></TABLE>
Yup
Yup
