Question Bout stereo in a civic!
Old Sep 1, 2008 | 08:30 PM
demian22's Avatar
Default Question Bout stereo in a civic!
I was installing a stereo in my civic a 94, this is the second stero in this car, with the 1st one everythng was working perfect but now whe i finished the stereo did turn on, so i did a lil searching on the wiring and found out that the memory wire from the car's harness doesn't have any voltage, i need help what could be the cause? Any input will be awesome, thanx!
Old Sep 1, 2008 | 08:34 PM
94EG8's Avatar
Seagull Management
Default Re: Question Bout stereo in a civic! (demian22)
check the backup fuse under the hood, 7.5amps i believe.
Old Sep 1, 2008 | 08:35 PM
jimmy o.'s Avatar
hmm i had the same prob in my 93 i just ran a wire for a 12 volt source in the fuse box that wasent used would like to know what happened (had no blown fuses)
Old Sep 1, 2008 | 08:36 PM
demian22's Avatar
Default Re: Question Bout stereo in a civic! (94EG8)
Thanx ill do that!!!
Old Sep 1, 2008 | 08:37 PM
demian22's Avatar
Default Re: (jimmy o.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmy o. &raquo;</TD></TR><TR><TD CLASS="quote">hmm i had the same prob in my 93 i just ran a wire for a 12 volt source in the fuse box that wasent used would like to know what happened (had no blown fuses)</TD></TR></TABLE>
I already check all the uses and nothing its wrong either!
Old Sep 1, 2008 | 08:39 PM
demian22's Avatar
Did you ran a wire to the stereo, or to the main memory wire on the car's harness?
Old Sep 1, 2008 | 08:40 PM
demian22's Avatar
Default Re: (demian22)
Oh forgot to mention that my clock dont work either!!
Old Sep 1, 2008 | 08:43 PM
jimmy o.'s Avatar
i just used a 20 amp fuse and peice of wire and ran it to a constant 12 volt source in the fuse box havent had any problems since i know its a lazy way to fix it but i have to do enough wiring on everone elses cars lol
Old Sep 1, 2008 | 08:47 PM
demian22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmy o. &raquo;</TD></TR><TR><TD CLASS="quote">i just used a 20 amp fuse and peice of wire and ran it to a constant 12 volt source in the fuse box havent had any problems since i know its a lazy way to fix it but i have to do enough wiring on everone elses cars lol</TD></TR></TABLE>
LOL, but to the yellow wire of the stereo right? or to the white/blue original wire of the car? Am confused
Old Sep 1, 2008 | 08:51 PM
jimmy o.'s Avatar
yes the yellow one ive owned three hondas with hacked up stereo wiring i wish i could find one with the install harness in it lol
Old Sep 1, 2008 | 08:53 PM
demian22's Avatar
LOL, thanx for the info man i'll work on it tomorrow!!!
Old Sep 1, 2008 | 08:57 PM
jimmy o.'s Avatar
no problem
lazyweasal4
Audio / Security / Video
Dec 12, 2006 04:06 PM
escape2me
Apr 26, 2006 05:34 AM
themackingking
Jul 25, 2004 07:24 AM
acurciv
Aug 27, 2003 08:53 AM
phathodna35456
May 20, 2003 08:04 PM
