will other flywheel bolts fit h series?
Order them from Honda.
H-series flywheel bolts ... http://slhondaparts.com/browse...=true
Number 8 in the diagram, part no. 90011-PH3-000
check on http://www.hondaautomotiveparts.com and see if the part numbers are the same.
I have a feeling he wants some ARP flywheel bolts but since they only make them for b and D series motors, he wants to know if he can use them with his H. That's what I'm thinking lol, I was wondering the same thing the other day when I was swapping flywheels
D, B and H series flywheel bolts are all the same.
The difference is not in the Engine type, it is in the Transmission type.
Difference is Auto and 5 speed bolts.
The auto "flywheel" bolts are shorter. I put flywheel in parenthesis because its not really a flywheel.
The 5 speed flywheel bolts can be interchanged throughout the above engine codes.
The auto "flywheel" bolts also have AT stamped on the head so you know, incase looking and seeing they are physically shorter was too much work . . .
Hope that helps
Hope that helps
team1320_k26eg
Jan 13, 2007 05:35 PM
