belt squeek?...can someone help please?
Old Sep 1, 2008 | 03:48 PM
pinky5's Avatar
Default belt squeek?...can someone help please?
for some reason it seems as if my belt is squeeking...i understand that if moisture gets on it it will make it whistle but im getting the noise during the day and the belt looks good...maybe te pulley?
thanks
pinky
Old Sep 1, 2008 | 04:31 PM
-.1234P312.-^EK_SI^'s Avatar
Default Re: belt squeek?...can someone help please? (pinky5)
make sure you have the right belt on it and it is routed right, but if thats all good yup prolly a pulley is loose, most likly a tensionor bearing. good luck
Old Sep 1, 2008 | 04:40 PM
slvrcvc93's Avatar
Default Re: belt squeek?...can someone help please? (-.1234P312.-^EK_SI^)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -.1234P312.-^EK_SI^ &raquo;</TD></TR><TR><TD CLASS="quote">make sure you have the right belt on it and it is routed right, but if thats all good yup prolly a pulley is loose, most likly a tensionor bearing. good luck </TD></TR></TABLE> since when did Honda's have tensioner pulleys ?? even though the belt looks good could be dry a easy thing that can help is not belt dressing because it drys up use silicone spray. But before you do all that take off the belts spin the pulleys look for wobbles, and that they spin freely.
Old Sep 1, 2008 | 05:26 PM
alphalanos's Avatar
Default Re: belt squeek?...can someone help please? (slvrcvc93)
I think he meant timing belt. Are all your belts new?
Old Sep 1, 2008 | 06:19 PM
x1xofakindx's Avatar
Default Re: belt squeek?...can someone help please? (alphalanos)
make sure the tension is done right in the first place too cause if they are too tight or loose it can cause it
Old Sep 2, 2008 | 04:40 AM
Burnt Toast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphalanos &raquo;</TD></TR><TR><TD CLASS="quote">I think he meant timing belt. Are all your belts new? </TD></TR></TABLE>
Timing belts don't squeel. Its the alternator belt and its probably loose. Tighten the belt.
mikey88
Apr 19, 2017 10:57 AM
NtheWorks
May 9, 2007 05:17 AM
Dupes
Aug 17, 2005 01:43 PM
JMod
16
Jun 23, 2005 11:49 AM
J T*
14
Apr 5, 2002 06:21 PM
