wtf is going on!!!
Old Sep 1, 2008 | 10:21 AM
ek2588's Avatar
Default wtf is going on!!!
i have a 88 ef civic with a OBD0 b16a swap. on a cold start the engine starts up fine and idles fine but runs really rich (according to my narrow band a/f gauge ) While driving there really is no problem other the slight back fire during shifts, and the fact that it doesnt go into vtec, but thats due to the knock sensor code. The ecu is showing codes for map sensor and knock sensor (3 and 23). If i turn the engine off after it has warmed up and then turn it back on its runs like ****. It begans to idle erodicately(sp) as if the dizzy gone bad. At full throttle the rpm doesn't rise above 1k. If put it into gear the engine immediately stalls. If i shut the engine off for like 10 min and start it up again it runs fine (well for the most part) i checked for voltage in the map plug and it was 5.02 v wich i guess is good since its a 5v ref. sig. but it had over 200 ohms of resistance, ive tried several diff map sensors but the code doesn't go away. Ive searched for this many times bvut have not found the answer. wtf is going on? any help is greatly appreciated
Old Sep 1, 2008 | 01:17 PM
ek2588's Avatar
Default Re: wtf is going on!!! (ek2588)
...anybody plz
Old Sep 2, 2008 | 08:24 PM
srmofo's Avatar
dunno what the resistance should be, search for that...but have you double checked that the vacuum hoses are not broken or going to the wrong places
Old Sep 3, 2008 | 12:26 PM
ek2588's Avatar
Default Re: wtf is going on!!! (srmofo)
yea every thing is is the way it should be as far as vacuum hoses go. i need to gain access to a vac. guage to see how much vacuum im getting.
HX35_Ek_Hatch
Jan 15, 2013 07:29 PM
joshd_bh
Jan 13, 2013 04:21 PM
balliso911
Feb 6, 2011 07:24 AM
ek2588
Sep 3, 2008 01:55 PM
Poptart
Aug 25, 2006 03:27 PM
