Transmission & Drivetrain Gearboxes, Differentials, Clutches
how many cans of mobil 1 gear oil in gsr tranny?
Old Sep 1, 2008 | 10:02 AM
Eklsv-t's Avatar
Default how many cans of mobil 1 gear oil in gsr tranny?
Mobil 1 Synthetic Gear Lubricant LS 75W-90-How many cans do I need for gsr tranny turbo car
Old Sep 1, 2008 | 12:27 PM
Aquafina's Avatar
None. Gear oil is a no-no.
Old Sep 1, 2008 | 04:08 PM
DC209's Avatar
Default Re: how many cans of mobil 1 gear oil in gsr tranny? (Eklsv-t)
LOL
Old Sep 6, 2011 | 06:44 PM
shawnlee250's Avatar
Sorry for the old bump but what wrong with mobile 1 gear oil 75w90 LS?
I'm doing my tran flush on my 04 civic 5 speed. What the matter with gearbox oil?
Old Sep 7, 2011 | 05:12 AM
kyden's Avatar
gear oil is too thick.
Old Sep 7, 2011 | 06:38 AM
Russyo's Avatar
honda uses MTF, or regular motor oil in the manual trans. Gear oil would gum it all up pretty bad and slow down the syncros. Def not a good idea.
the amount would depend on the model of transmission being used.
ex: GSR trans would hold roughly 2 1/2 quarts of MTF or oil.
Old Sep 7, 2011 | 09:10 PM
Honda Bull's Avatar
2 quarts. If that. 2.5 qts will have .5 quarts exiting the fill hole.
Old Sep 8, 2011 | 12:31 AM
Mista Bone's Avatar
D Tranny Guru
2.3 quarts for B's, overfilling with 2.5 quarts isn't a problem.
Old Sep 8, 2011 | 02:02 PM
integ2000lsv's Avatar
^ yep, 2.3 it is, Get 3 quarts of MTF, and fill with the plug out until fluid runs out, put plug back in, call it a day.
Old Sep 9, 2011 | 01:20 PM
Russyo's Avatar
I'd rather waste .2 of a quart than under fill it by the .3. Doubt it would matter that much either way tho.
Old Sep 10, 2011 | 02:10 AM
running .3 low is bad. run the correct amount
Old Sep 12, 2011 | 05:24 AM
Honda Bull's Avatar
I wouldn't be concerned about wasting it at all. But you can't exactly purchase half quarts of Honda MTF, Torco MTF, Amsoil MTF, etc. They come in full quarts. So you wouldn't be wasting .2. You'd be saving .7 for the next change.
Yeah? And what testing have you done for that? You'll be amazed at what the K-series runs despite being a larger trans housing and slightly larger gear set then...
You realize that, unless you have the trans completely torn down and cleaned out, there is still fluid left in the trans. This maintains that you use two different fill amounts depending on the scenario. 2.3 qts is recommended for the overhaul. A fluid change will not take as much.
Old Sep 12, 2011 | 06:52 AM
Yes I realize there is still a small amount of mtf in the trans when doing just a drain and refill. But what you need to realize is that when you fill to the proper level, it WILL run out the fill/check hole, and that it is in fact, 2.3 qts inside the case. I was saying to run the correct amount by doing this in my post before the one you have quoted, and another member said that not filling all the way up is ok (2 qts i believe he said), when that is false, all i said, was use the correct amount. Thats not to hard to do, really.
Now if you want to ask about testing I have done, then I will tell you this. I have been working with Synchrotech for year testing new products for them and trying new tricks here and there. So please, insted of getting into a pissing contest, just follow instructions. Honda engineers are some of the best in the industry, and I'm sure they know what they are talking about.
Who said anything about a K...? Whole new beast there.
petty$rep
26
Jun 29, 2024 10:21 AM
jdm702
Apr 15, 2010 04:50 AM
MtnCRX
26
May 24, 2005 05:53 AM
MtnCRX
Apr 24, 2005 06:36 PM
WS6Dreams
Nov 26, 2002 07:36 PM
