Lightweight Crank Pulley
Old Sep 1, 2008 | 09:26 AM
SPOONfed-Rex's Avatar
Default Lightweight Crank Pulley
I have a stock 99 GSR block. I was wondering if the internals have to be balanced if I change the crank pulley to a lightweight one.
Old Sep 1, 2008 | 09:45 AM
kalm_traveler's Avatar
Default Re: Lightweight Crank Pulley (SPOONfed-Rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOONfed-Rex &raquo;</TD></TR><TR><TD CLASS="quote">I have a stock 99 GSR block. I was wondering if the internals have to be balanced if I change the crank pulley to a lightweight one. </TD></TR></TABLE>
No, when you get the 'rotating assembly' balanced by a shop that's just referring to crank, rods+pistons.
I lighter crank pulley would be roughly the same as throwing a lighter flywheel on as far as affecting engine balance.
In other words, don't worry about it
Old Sep 1, 2008 | 10:14 AM
Wow... Finally a decent answer...Sweet thanks for the info
Old Sep 3, 2008 | 08:32 PM
FRU's Avatar
FRU
If you are getting rid of the stock pulley with the injected rubber in it for a solid metal pulley with no damper such as the ctr you may want to do some more research. The rubber is in the stock pulley to absorb some of the vibrations coming off of the crank that could possibly wear out bearings faster. It seems some people have no problems running pulleys like the ctr but most people with high horsepower motors use a damper such as an ATI or Fluidamper which do what the stock pulley does except better. Personally I would just stick with the stock pulley.
DARKTEG_
13
Aug 14, 2006 02:24 PM
asefi944
Apr 11, 2005 02:26 PM
works909
Mar 3, 2005 11:42 AM
airwalk07143
Sep 24, 2004 07:40 AM
crx00
Sep 28, 2003 11:02 AM
