just got my r of the dyno and wanted to know what other people are putting down.
Old Jul 24, 2002 | 12:14 PM
QuestRacing-TypeR's Avatar
Default just got my r of the dyno and wanted to know what other people are putting down.
please list power and torque with all ur mods and 1/4 times would be nice too
Old Jul 24, 2002 | 12:15 PM
PhxK20a3's Avatar
Default Re: just got my r of the dyno and wanted to know what other people are putting down. (QuestRacing-Ty
so what did it lay down?????
Cosworth's Avatar
I dyno-ed bone-stock @ 162.8whp and ~118.xxx lb-ft torque.
I don't drag, so I don't know the 1/4mi times.
Old Jul 24, 2002 | 12:17 PM
BlackAckeR's Avatar
That torque sounds a bit low, isn't it?
Old Jul 24, 2002 | 12:34 PM
Rob :190:'s Avatar
comparing other peoples dyno numbers is completely pointless. so many variables effect the numbers. what jon X put will more than likely be a lot different that what jon q put down, even with the same mods.
Old Jul 24, 2002 | 12:45 PM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
If you don't have much miles on the motor then it will dyno pretty low. I put down 176hp (Can't remember tourque with a screwed up header/exhaust/and small CAI. I put down 185hp and 138 tq with Toda spec B's. Although peak wasn't as high as I'd like (Needed bigger injectors and higher compression to wake the cams up) the Low and mid range on this cams were unbelieveable.
I shredded a timing belt and the motor took a major hit. So I'm in the process of getting a brand new motor and I will go with spec C's next year.
Old Jul 24, 2002 | 01:54 PM
f1nal zeros's Avatar
i put down max power 175.1 @ max torque 129.1
done in 109 degrees
Old Jul 24, 2002 | 01:58 PM
Austin's Avatar
190-195whp...13.7
Old Jul 24, 2002 | 02:42 PM
ZygSpeed's Avatar
Nice, Austin!
Old Jul 24, 2002 | 02:58 PM
Austin's Avatar
Nice, Austin!
Thanks Ed...that was with the TODA setup, with cat, 91 octane, power steering, and tuned for the mid-range...now I have no clue as to what I'm putting out, although I should know by next weekend
Old Jul 25, 2002 | 09:45 AM
i put down 175.1 for max power and 127.1 for max torque
all down in 110 degrees
Old Aug 15, 2002 | 02:45 PM
2001TypeR's Avatar
weird, ive seen an itr with 185 whp do a 13.6.....with some tires tho but still...who knows different climate and elevation i guess...
Old Aug 15, 2002 | 03:08 PM
JohnnyBoy's Avatar
Stock: 163.5HP 115TQ
1/4 mile 14.6 @ 97mph
Art Vandeleigh's Avatar
here is mine. i had about 5k on the motor at the time and is bone stock.
what did you put down?
Old Aug 15, 2002 | 03:16 PM
AllMotorMadness's Avatar
238whp/153tq IB Package 3......expecting 11's when I hit the track in the next few weeks
[Modified by AllMotorMaddness, 4:17 PM 8/15/2002]
Old Aug 15, 2002 | 03:18 PM
canuckr's Avatar
Stock with a Comptech Ice Box and no power steering:
176whp/126tq
Old Aug 15, 2002 | 03:28 PM
RTW DC2R's Avatar
178hp, AEM, USDM Spec Mugen 4-1 header, no p/s belt
14.75@94mph(stock, first time ever at the track)
Old Aug 15, 2002 | 03:30 PM
176whp/126tq
damn the ice box netted you that much?? i have one too, but i have not dynoed yet with the ice box. that is great!!!! what was your stock like?
Old Aug 15, 2002 | 06:57 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
230 whp/193 ft/lb torque - NOS 70 shot with boltons, but read sig
Old Aug 15, 2002 | 07:23 PM
98R-1144's Avatar
164.4 / 116.1...just AEM CAI
Old Aug 15, 2002 | 07:43 PM
JDMAllMota R731's Avatar
192whp 132lbs torque...Re-dynoing the car again in two weeks....Imma post new results later.....
Old Aug 15, 2002 | 07:58 PM
PM-Performance's Avatar
i/h/e/test pipe. fpr. ffuel rail , fuel pump . 18 degree timing no ps. . . untuned and rich as hell .186.1@130.1 ft/lbs
will be pulling 300 whp when the direct port is finshed and all tuned up
Old Aug 15, 2002 | 08:04 PM
Splat's Avatar
Collector-o-Guns and Drinker
AEM CAI, JDM 4-1, Jeg's 2.5" cat, stock cat-back, V-AFC
Old Aug 29, 2002 | 06:55 PM
New dyno results from AREA51....198whp 132lbs trq...
acura_b18c1
21
Oct 8, 2009 11:42 AM
Bradstard
Aug 19, 2004 01:58 PM
ITRJunkie
Jun 28, 2003 02:18 PM
CStyles45
Sep 7, 2002 02:16 AM
01PYTypeR#1140
May 7, 2002 01:37 PM
