Cam Choice need some info plz
Old Aug 31, 2008 | 08:22 PM
levee000's Avatar
Default Cam Choice need some info plz
I need some choices for cams on my setup. I have a choice of CTR cams or Skunk2 stg2 TUNERS for dirt cheap but im open to others idleing wont be an issue but i do wanna watch my lift duration shootin for over 200whp
plz chime in im open to any info or help
heres my setup
GSR block w/LS crank
Eagel rods
SRP pistons 10.7:1 in a straight LS stock bore
Head--
JG mani
70mm bbk tb
B16 race port head
Supertech flat valves
Supertech Dual Valve springs w/ TI retainers
Supertech valve seals
Modified by levee000 at 9:51 PM 8/31/2008
Old Sep 1, 2008 | 05:44 PM
gmen08's Avatar
Default Re: Cam Choice need some info plz (levee000)
alot of people on the forum use skunk 2, and they say that it produces a good amount of power and the idle is pretty good too
Old Sep 1, 2008 | 05:45 PM
levee000's Avatar
i jus need a opinion if those 2 cam choices i ahve are reliable for 200whp
Old Sep 1, 2008 | 07:15 PM
gmen08's Avatar
You could probably achieve your goal with both cams, but i think you will have better results with skunk 2
for more specific results look at this link https://honda-tech.com/zerothread/1583606 , and then look for similar builds that you are trying to do
boostedb20ek
Apr 21, 2010 09:23 AM
94cpe
Dec 18, 2009 06:28 PM
RIPED AIMAL
Aug 17, 2009 08:12 PM
boosh
Jan 4, 2008 01:32 PM
Will_H
May 16, 2005 08:57 AM
