B20 Rod Question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKid936 »</TD></TR><TR><TD CLASS="quote">Ok im building an b20 short block with all b20 rods and all but is there a difference between me using the b20 rod caps or can i use ls rod caps???
Definitely don't use rod caps from a different rod unless you want a spun bearing.
</TD></TR></TABLE>Definitely don't use rod caps from a different rod unless you want a spun bearing.
rods are machined (for bearings) with the caps on and bolts torqued to spec. if you don't want problems or to remachine rods, use only those in good condition with their proper caps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gmen08 »</TD></TR><TR><TD CLASS="quote">Well he could use brand new LS rod caps right?</TD></TR></TABLE> Where would you get them? Not from Honda/Acura.
i wouldn't try to fit a square piece into a circular hole. stick with the same rod caps. is there something wrong with the original B20 caps??
</TD></TR></TABLE>i wouldn't try to fit a square piece into a circular hole. stick with the same rod caps. is there something wrong with the original B20 caps??
especially since they are oem rods, id rather just get another set than try and mixmatch caps.
however, you should be able to get the big end honed out to make it perfect, but you would have to measure and plastigauge to find the right bearing size instead of being able to follow the crank/rod markings as in the helms
Lost H
Jul 12, 2008 03:39 PM
