Burning oil? Help
Old Aug 31, 2008 | 03:36 PM
stevanrk's Avatar
Default Burning oil? Help
So I have been noticing that every oild change, which I do myself, I haveabout a quart of oil after 2500 miles of driving. I fill it with just over 3 quarts and use the dipstick to check the level needed. This last time I let it go to 4000 miles cause I was busy and the oil light started to flicker. I checked the levels and the stick showed empty. A TINY bit of oil on one of the corners of the stick, but that's it. I changed my oil and no oil lihgt problem anymore, but obviously I still have a oil loss problem. My car seems to run fine and I never notice any smoke coming out the back. I have changed the oil filter with the oil every time. I use Mobil 1 5w30 and saw somewhere that this oil is known to burn. Is it burning slowly enough for me not to see it or could this be a different problem? The only other thing I am doing to my car is adding FP60 oil additive and when I can FP60 fuel additive to clean things out and keep them clean. Any thoughts are appreciated. What should I check and should I change oil? Thanks
Steve
Old Aug 31, 2008 | 03:47 PM
slvrcvc93's Avatar
Default Re: Burning oil? Help (stevanrk)
Well First thing you should be looking for is Blue smoke out the exhaust. If not next would be a compression test if that seems normal than a leakdown test to see if your valve stem seals are fried. when you change your oil does it come out looking black as hell?
Old Aug 31, 2008 | 04:04 PM
BlackDeuceCoupe's Avatar
HT White Ops
CaSITE Motor Honey Oil Stabilizer, aka Gorilla Snot, is your friend!
http://www.casite.com/product....tID=1
If you're a cheapskate...
Old Aug 31, 2008 | 05:08 PM
stevanrk's Avatar
yes even at 2500 mile changes my oil has always looked black. what does that mean? Valve seals? Should I just get a gasket kit for the top stuff? Thanks
Old Aug 31, 2008 | 05:09 PM
stevanrk's Avatar
oh and no smoke at all
will have to get a compression tester to do that.
highwhey
Nov 11, 2010 05:53 AM
nick_622
Honda Civic (2001 - 2005)
10
Apr 20, 2009 04:54 PM
redLUDEs2k1
Oct 12, 2005 10:21 AM
chuckus
Oct 22, 2004 02:45 PM
Puki
May 19, 2003 11:56 AM
