ACT 6puck on gsr pressure plate and flywheel
Wouldn't you get the pressure plate with the clutch disk? I ran a six puck with a LS, some advice:
Upgrade your mounts
Make sure your stereo is in nice and tight, or you might knock out someone in the back seat
Have good cup holders before you start driving with a hot cup of coffee
Upgrade your mounts
i've done it....buying the whole kit would be smarter. those clutches are like on/off switches though. why do you need such an aggressive clutch anyway? are you using R compound tires, or?
the rule of thumb with clutches is "go with least amount of clutch is necessary"
if you have a bone stock B-series pushing no more than 130ft lbs to the wheels, then a full faced street clutch will be fine.
no need for an unsprung 6 puck rated for 350ft lbs. you'll just add more wear and tear to driveline parts. and unsprung clutches wreak havoc on things like motor mounts, trans cases, thrust bearings, mainshaft/countershaft bearings in your trans, etc.
if you're getting a heavy clutch so you can chirp 5th with your pep boys tires, then go for it.
got the 6puck disc from a friend who never used it. He didn't have the complete kit just the disc other wise'''''''....But yeah I switch my clutch already with the 6puck and my clutch is alot softer then I expected. I mean really soft, softer then bone stock.... any help please?
S1LENT94D00R
Transmission & Drivetrain
Oct 14, 2012 07:12 PM
S1LENT94D00R
Oct 13, 2012 11:42 AM
JDM turbo DC
Oct 19, 2006 09:21 AM
Yes or
No? Anybody out there have this set up? Or know anyone that does? and hows it running
