i have a 2000 honda civic dx ac compressor
Old Aug 30, 2008 | 10:17 PM
skateboard c's Avatar
Default i have a 2000 honda civic dx ac compressor
aight noob question i have a 2000 honda civic dx and im swaping a 1994 acura gsr complete swap in my car but i want to keep the ac do i need to purchase a 2000 honda civic si ac compressor will everything be plug and play. Will my stock ac line plug in to the new 2000 honda si ac compressor and will the 2000 si ac belt fitt on the gsr motor?
thanks in advance
Old Aug 31, 2008 | 07:01 PM
Default Re: i have a 2000 honda civic dx ac compressor (skateboard c)
anybdoy
Old Aug 31, 2008 | 07:19 PM
jeffnerette's Avatar
use your stock compressor everything should bolt up perfect except for the bracket only two srews will bolt up but itll work fine no problems.
Old Aug 31, 2008 | 08:29 PM
Default Re: i have a 2000 honda civic dx ac compressor (jeffnerette)
and what about the ac pulley on the block will the stock belt work
Old Sep 1, 2008 | 03:56 PM
no problem????
Old Sep 1, 2008 | 06:02 PM
anybody
Old Sep 1, 2008 | 06:12 PM
94EG8's Avatar
Seagull Management
Get a '99 CR-V A/C compressor bracket or one from a del sol dohc vtec, both work, they let you bolt up a d-series compressor to a b-series block.
Old Sep 1, 2008 | 09:13 PM
no need to spend money on a new bracket it works fine with the stock bracket. you have to use the belt from the dual cam,the single cam one is to short.
K_1
Mar 6, 2011 06:16 AM
mcvic
Jun 24, 2010 02:41 PM
sihatchyvtec
Mar 16, 2003 07:08 PM
Ehron
Jan 4, 2003 05:13 AM
