Fuel Question
Old Aug 30, 2008 | 10:09 PM
Shaynepolevault's Avatar
Default Fuel Question
So I loosened the gold bolt on the fuel pump or filter thing in the engine bay to see if i was getting any fuel, and now it leaks i cant tighten it. IS ther a trick, or how do you tighten it like all the way down? any help greatly appreciated.
Old Aug 30, 2008 | 10:15 PM
dohczccrx's Avatar
Default Re: Fuel Question (Shaynepolevault)
it tightens just like you loosened it just turn the wrench right instead of left
Old Aug 30, 2008 | 10:18 PM
Kendall's Avatar
There are small washers which are designed to be "squished" a little bit and therefore provide a good seal when the bolt is first tightened on them. Replace those and report back.
Old Aug 31, 2008 | 11:27 AM
Default Re: (Kendall)
yeah I replaced them it worked out good tightened down and no leak. thanks.
EG-SIXV-TEC
Dec 24, 2009 01:15 PM
jpnucrx
May 14, 2006 09:30 PM
95GS-R
Sep 5, 2002 03:47 PM
Mikey3000
May 16, 2002 11:59 AM
