00 EX rear disc conversion - questions
Old Aug 30, 2008 | 04:20 PM
HyperXK's Avatar
Default 00 EX rear disc conversion - questions
I want to change the drums I have in the back to dics brakes. I have an opertuniy to buy all this for 300.
"Ill sell you the trailing arms, rear rotors, all 4 calipers, front slotted and drilled rotors, front camber arms/control arms, brake master cylinder, and prop valve all for $300 its a STEAL all these parts are clean and werent beat on. Car had low mileage too and all calipers have good brake pads with lots of life left in them. This is the whole conversion as a complete package deal the only thing you'll need is ebrake cables THATS IT!!!"
What you guys thinks??? Are the GSR front calipers and rotors bigger then what I have on my car now?? Is this worth it to get all this for 300? or should I just buy the rear trailing arms for 100?? tried searching on here and google. even saw the tread on here about it, but it just confused me.
Sorry if this has been broght up already, but need to let him know what I'm gonna do really quick..
thanks
Old Aug 30, 2008 | 04:27 PM
Ksoulja's Avatar
Default Re: 00 EX rear disc conversion - questions (HyperXK)
Sounds like a good deal, a steal indeed.
Old Aug 30, 2008 | 04:37 PM
HyperXK's Avatar
Default Re: 00 EX rear disc conversion - questions (Ksoulja)
but is it worth if for the front setup?? i only wanted the rear conversion.
Old Aug 30, 2008 | 04:52 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyperXK &raquo;</TD></TR><TR><TD CLASS="quote">but is it worth if for the front setup?? i only wanted the rear conversion.</TD></TR></TABLE>
No, EXs have the same front brakes as a '94 - '01 integra. The EX should also already have the proper prop valve and master cylinder.
Old Aug 30, 2008 | 07:43 PM
HyperXK's Avatar
Default Re: 00 EX rear disc conversion - questions (94EG8)
so You think I should just give him $100 for the trailing arms??
Old Aug 31, 2008 | 06:08 AM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyperXK &raquo;</TD></TR><TR><TD CLASS="quote">so You think I should just give him $100 for the trailing arms??</TD></TR></TABLE>
Thats a pretty reasonable price, I think I pain $125 for mine, but they had almost brand new pads and rotors on them and they had the parking brake cables. Try to get the rubber flex hoses with them btw, you can't reuse your old ones and flex hoses aren't all that cheap if i recall.
Old Aug 31, 2008 | 06:23 AM
HyperXK's Avatar
what are thses and where are they located on this setup?? Im new at this so dont know what to really look for. So I wont need to go out and fina a 4040 prop valve? just Si E-brake cables? Im surpried I can't fina a decent DIY write up on this for 96-00 EX civics
Modified by HyperXK at 7:37 AM 8/31/2008
Old Aug 31, 2008 | 06:37 AM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyperXK &raquo;</TD></TR><TR><TD CLASS="quote">what are thses and where are they located on this setup?? Im new at this so dont know what to really look for. So I wont need to go out and fina a 4040 prop valve? just Si E-brake cables? Im surpried I can't fina a decent DIY write up on this for 96-00 EX civics</TD></TR></TABLE>
The flex hoses or flex lines connect to the metal hard lines on the chassis and go to the calipers, theres one on each side. cars with rear discs use completely different flex hoses. No you don't need a 4040 prop valve. Yes you need Si e-brake cables, pretty much any '88 - '00 civic or '90 - '01 integra with rear discs should work actually. but if your buying new go with '99 - '00 Si cables. Oh heres a writeup, its actually right in the '92 - '00 FAQ Index https://honda-tech.com/zerothread?id=641639
Old Aug 31, 2008 | 06:41 AM
HyperXK's Avatar
Not sure if you can tell, but heres what hes got...
Old Aug 31, 2008 | 06:46 AM
94EG8's Avatar
Seagull Management
From the angle of the picture I really can't tell. But if you look at them its basically a rubber hose coming off each caliper about 2 feet long. make sure they aren't cut or missing.
Old Aug 31, 2008 | 06:52 AM
HyperXK's Avatar
i'll send him a PM and ask, thanks
Old Aug 31, 2008 | 07:12 AM
TheCoupeDeuce's Avatar
thats a good price for all that, i got lucky my friend parted out his car and i got mine for pretty cheap, anyways i did this when i was kinda new into messin around with the car its not hard at all just take your time remember where stuff goes your should replace the brake lines for steel braided lines while your at it
Old Aug 31, 2008 | 07:44 AM
HyperXK's Avatar
Default Re: 00 EX rear disc conversion - questions (TheCoupeDeuce)
But is all that stuff for the front better? 94EG8 says that its the same thing up front, So i'm only goin for the rear trailing arms.
Modified by HyperXK at 9:32 AM 8/31/2008
Old Aug 31, 2008 | 06:32 PM
HyperXK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 &raquo;</TD></TR><TR><TD CLASS="quote">From the angle of the picture I really can't tell. But if you look at them its basically a rubber hose coming off each caliper about 2 feet long. make sure they aren't cut or missing.</TD></TR></TABLE>
I don't think they come with the hoses, he said he didnt think so, so are they worth it? or should I just wait
Old Aug 31, 2008 | 07:51 PM
94EG8's Avatar
Seagull Management
Price the flex hoses, see exactly what they are worth, $100 isn't a bad price if the pads and rotors are good and the wheel bearings are good. The biggest thing is to make sure that the calipers aren't seized, those are expensive if you can't get them freed up, a friend of mine had to replace both one year, it seems to me they were something like $200 each for rebuilt calipers, with core. From the pic the trailing arms look to be in good shape, even the dust shields are in good shape, mine were rotted off before i got mine so I have none. Anyway, price some flex hoses and then decide what you want to do.
Comenzi SUA
12
Dec 8, 2015 06:33 PM
KYLE.ECKERT
Mid-Atlantic (Sales)
Oct 11, 2006 04:27 PM
KYLE.ECKERT
Northeast (Sales)
Corran
Jan 2, 2004 07:55 AM
HYBRIDHATCH92
Mar 9, 2002 02:40 AM
