new headliner for car with possible aftermarket sunroof?
Old Aug 30, 2008 | 04:01 PM
BROKE.eg's Avatar
Default new headliner for car with possible aftermarket sunroof?
what are my options? im pretty sure this car has an after market sunroof and i need a whole new headliner.
Old Aug 30, 2008 | 06:45 PM
NOFX's Avatar
H-T White Ops
Post photos of the moonroof and we can probably tell you.
OE roofs have the seal on the glass because the roof panel folds in around the hole in the roof. Aftermarket ones have the seal on the roof skin.
If it's aftermarket you're going to want to either redo your current headliner or cut a hole in a headliner that's for a car without a moonroof.
Old Sep 2, 2008 | 09:58 AM
BROKE.eg's Avatar
Default Re: (NOFX)
its definetly aftermarket then, the seal is not on the glass. Would an OEM sunroof headliner not fit an aftermarket sunroof?
Old Sep 2, 2008 | 10:14 AM
NOFX's Avatar
H-T White Ops
Default Re: (BROKE.eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BROKE.eg &raquo;</TD></TR><TR><TD CLASS="quote">its definetly aftermarket then, the seal is not on the glass. Would an OEM sunroof headliner not fit an aftermarket sunroof?</TD></TR></TABLE>
Probably not. The likelihood that an aftermarket company that makes a universal moonroof/sunroof based it off of the exact dimensions of a 6G Civic moonroof is low.
The moonroof might be wider or thinner side to side or might be longer or shorter front to back.
So you'll end up with a hole in the headliner that's the wrong size and/or shape.
Old Sep 3, 2008 | 12:31 PM
BROKE.eg's Avatar
what would be the easiest way to get the hole right from a non moonroof headliner?
vtecx2
11
Mar 22, 2010 01:22 PM
Tatakai
Honda S2000
24
Nov 4, 2008 09:57 PM
Rahxephon
Honda Fit
11
Dec 17, 2006 10:54 PM
kourjakian
Sep 18, 2003 05:49 AM
