Aem Cam gear problem/Question
Old Aug 30, 2008 | 01:41 PM
Paul-eg's Avatar
Default Aem Cam gear problem/Question
Hey,
I have aem true time cam gears on my high comp GSR. I got tuned few months ago 171wh 130 TQ and tuner was going to play with cam gears but noticed that one had a torx bit broken in it and one was a bolt so we didn't mess with them(prev owner must of done this). So now I am going to tune my car again for nitrous since I have everything ready to go and I would like to tune the cam gears as well this time.
I want to replace all the screws. Anyone know off hand what kind I will need? Also what will be the easiest way to get them all off including the one with the broken bit. They all looked a little stripped. Would taking the gears off be the easies route?
Thanks
Old Aug 30, 2008 | 02:56 PM
1992Si's Avatar
I would think taking them off is the best thing to do. then replace them.
A lot of us have the small needle nose vise grips that work well on screws. You can sometimes grab the side of the head and use the vise grips like a breaker bar. I would put hex bolts back in.
Don't over tighten them.
Old Sep 1, 2008 | 03:33 PM
PyroProblem's Avatar
Default Re: (1992Si)
I replaced mine with some little allen head bolts from home depot.
theyre stainless and have a bigger(harder to strip) head also...
Some lock washers are also a good idea
Old Sep 2, 2008 | 08:20 PM
srmofo's Avatar
Default Re: (PyroProblem)
I would replace with grade 8 bolts....if you have a dremel or cutoff wheel, you should be able to slot the bolts and use a flathead, do em 1 at a time and you wont have to retime , make sure you stuff arag in between the cover and block to keep chunks of wheel and metal out of the timing belt area
lsvtecEM1
Apr 6, 2010 07:28 PM
JFG Kevin
21
Dec 8, 2004 08:30 PM
smkngsr
Apr 11, 2002 04:33 AM
b18c-93
Mar 21, 2002 06:06 PM
jabroni95gsr
Nov 1, 2001 03:20 PM
