clutch will not disengage above 4000rpms
Old Aug 30, 2008 | 12:56 PM
patrick4588's Avatar
Default clutch will not disengage above 4000rpms
basically if im above 4000rpms and push the clutch in, it wont disengage until the rpms drop below 4000. im not really sure what it could be. i swapped the clutch and that didnt do it, so im thinking master or slave cylindeR? i dont see any leaks from either though
Old Aug 31, 2008 | 12:57 PM
lmike6453's Avatar
To be sure of leaks, besides checking reservoir, check underneath slave cylinder from under car with much light at the pin holes in rubber to see if they're wet.
To check master cylinder, check behind the clutch pedal for gunky thick fluid or any fluid at all.
Old Aug 31, 2008 | 05:58 PM
yeah i dont see any leaks
jlowellintegra
Nov 27, 2010 08:15 PM
FRKWOO
Apr 5, 2009 03:58 AM
eg6sittingon57cs
Aug 8, 2007 10:44 AM
myhatchrips
Dec 5, 2003 07:21 AM
976
Sep 15, 2001 10:41 PM
