check engine o2 sensor
Old Aug 30, 2008 | 11:40 AM
boynblue's Avatar
Default check engine o2 sensor
from time to time my check engine light comes on then goes off. Checked the code and its for the o2 sensor upstream. Whats the location of this? I see 2 on the cat. Is it one of those 2? Do I need a special tool to remove it or just a deep socket? Got 70k on my ride do I need to replace or clean it?
Old Aug 30, 2008 | 03:13 PM
johnclaunch's Avatar
Default Re: check engine o2 sensor (boynblue)
You will need an O2 sensor socket. Have you modified the cat? or the internals of the engine? What code are you throwing? P0420?
Old Aug 31, 2008 | 01:39 PM
boynblue's Avatar
Default Re: check engine o2 sensor (johnclaunch)
Thanks for the info. Never changed o2 before. No mods down there yet at all. Everything stock except for a stiffy. Engine light is off at the moment. I Lost the paper that I wrote the code on last time I stopped at the auto shop . It said o2 upstream was bad.
Old Sep 1, 2008 | 05:49 PM
thegod's Avatar
i would recommend changing the o2 sensor. i had a problem similar to that and changing it cleared it right up!
Old Sep 2, 2008 | 12:51 AM
SlimDC5's Avatar
It's the primary o2 sensor, the one before the cat. You will need a 22mm o2 socket to remove it
Old Sep 9, 2008 | 08:22 PM
kobeballer96's Avatar
i had this same problem with my ep3. i was just driving to work and the check engine light came on. i scanned it and it was a p1166 and a p1167. its just the o2 sensor. how much do they go for and it is easy to install one?
Old Sep 10, 2008 | 01:48 PM
Default Re: (kobeballer96)
P0166 and P0167.
They are easy to install. They run about $200.
Old Sep 12, 2008 | 08:43 AM
pcorad's Avatar
Default Re: (johnclaunch)
I've got a 1166/1167 following a clutch install.
Others have suggested a wire got pulled out from the sensor. I've looked, and pushed wires in, everything looks ok, but still get the codes.
Is replacing the O2 sensor a "guaranteed" fix? Is is possible a wire was pulled between the O2 connector and the ECU? I think that would be almost impossible to "push back in".
Old Sep 12, 2008 | 09:33 AM
nahonda04's Avatar
Surje.motorsports
Default Re: (pcorad)
someone else just had the same problem on here
https://honda-tech.com/zerothread/2385257
Old Sep 12, 2008 | 02:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcorad &raquo;</TD></TR><TR><TD CLASS="quote">I've got a 1166/1167 following a clutch install.
Is replacing the O2 sensor a "guaranteed" fix? Is is possible a wire was pulled between the O2 connector and the ECU? I think that would be almost impossible to "push back in".</TD></TR></TABLE>
Have you cleared the code to see if it comes back or will it not clear at all?
Old Sep 12, 2008 | 07:45 PM
crazyflip's Avatar
i got my o2 from a dealership, almost $300. suckssss. its not hard to put it in.
Old Sep 13, 2008 | 07:25 AM
pcorad's Avatar
It clears and comes back almost immediately.
Old Sep 13, 2008 | 09:28 AM
Check those wires before you spend hundreds on a new sensor.
blacksoul
May 23, 2009 08:50 PM
lsturbo*
Aug 15, 2007 07:40 AM
jxkim89
Dec 30, 2006 02:55 PM
silverboost
Aug 23, 2005 09:11 AM
wootcivic
Nov 29, 2004 10:01 AM
