im a little confused little asssistance please.
ok 90 crx si bone stock. my brakes are acting up and i cant diagnose the problem. i searched over 15 different issuses and perfomed the brake test and i dont know what up. the symptoms are as follows: my back brakes are touching the rear discs and as i begin to drive it gets worst but yesterday i took a ride around town and i almost had no braking ability, the pedal would sink to the floor but i could pump it back to life. fluid is good. any one have these same symptoms?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arora_808 »</TD></TR><TR><TD CLASS="quote">Bad master cylinder.</TD></TR></TABLE>
yep. do the brake booster check, If it's good, just the master cylinder. 70.00 at napa and easy to install.
I had the same issue, I took my car to Midas after to have the brakes bled too.
well i guess all of us are wrong b/c it was not my master cylinder. i bled the brakes ( farthest to closest from the mc) and i took the car out for a joy ride and still the same problem. oh yeah and note to all cover up your alternator when u make this change i managed to fry mine b/c i spilled brake fluid on when putting the mc back in. ten min into my joy ride my battery light came on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beige89civic »</TD></TR><TR><TD CLASS="quote">If you got rear drums check your wheel cylinders for leaks</TD></TR></TABLE>
I certainly second this, as the same thing happened to me. Moreover, when I had my 69 mustang (drums all round!!!) It was my front wheel cyls
its a 90 si (disc brakes all around). i did check for any leaks in the system by performing the leak test that haynes tells u to do. but i think that i mgonna change the rear calipers any ways just to be on the safe side. ill keep u guys updated when i solve the problem.
mattbatson
Oct 23, 2008 07:30 PM
I_love_my_HONDA
Apr 24, 2005 07:34 AM
