Unpin ECU-Plugs?
Old Aug 29, 2008 | 11:16 PM
Michael_[UR]'s Avatar
Default Unpin ECU-Plugs?
hi,
i want to tuck my wires and i'm going to unpin my ECU-Plugs
but i don't want to mess something up and don't know how to unpin this kind of plugs
the grey ones and the green like on this pic below
couldn't find any info
hope you can help me
thx
Old Aug 29, 2008 | 11:33 PM
ekb16's Avatar
there is usually some sort of locking tab that u just pull out, or unclip it to unlock the pins...then u find a unpining tool or a very small flatehead screwdriver and gently push up on the pin tabs to unhook them and pull it out at the same time
Old Aug 30, 2008 | 05:49 AM
Default Re: (ekb16)
hi,
thx
yeah. the round plugs of the headlights harness f.e. work like you're saying.
but i don't know how to unlock these
i opened them on both sides and they look like this plug now
but the pins are still fixed to the plug.
and the hoes on the other side are small
Old Aug 30, 2008 | 06:52 AM
silverbullet9626's Avatar
Default Re: Unpin ECU-Plugs? (Michael_[UR])
damn dude cut your finger nails
Old Aug 30, 2008 | 12:50 PM
Default Re: Unpin ECU-Plugs? (silverbullet9626)
that's not my hand. i have taken this picture here from another thread...
post something useful
Old Aug 30, 2008 | 04:15 PM
CivicSpoon's Avatar
http://technet.ff-squad.com/
Scroll down to the "ECU & Wiring Tech" part, find the correct OBD and you'll see the pin removal stuff there.
Old Aug 30, 2008 | 04:27 PM
NotNew's Avatar
Default Re: (CivicSpoon)
just did this about 20 minutes ago trying to fix my Gdamn VTAK.. anyway it was a bitch, but I used the center copper wire from Coax cable wire, I cut a little piece about an inch long with all the insulation taken off, and you push it in right above where the wire goes into the plug from the side with all the wires coming out.. and pull on the wire at the same time. It took about 10 minutes to get the first one out. I ripped on it pretty good and didnt damage anything, i wouldnt worry too much about breaking anything because you will probably have to wrestle it a bit to figure it out..
Old Aug 30, 2008 | 06:42 PM
Default Re: (NotNew)
@CivicSpoon:
thank you so much. thats what i searched for
@notnew:
i know what you talking about
i will try it just tommorow
redline5th
Jul 19, 2010 07:36 PM
loki2323
Audio / Security / Video
Sep 6, 2005 07:52 AM
Mugen Dom
20
Oct 13, 2004 03:36 AM
GripFactoR
Nov 21, 2003 02:36 PM
DarkSubRosa
Apr 16, 2003 11:47 AM
