should i do b18c5 turbo or high compression
Old Aug 29, 2008 | 11:04 PM
hondaekr's Avatar
Default should i do b18c5 turbo or high compression
im debating between both i am building the r either way but it just which way i wanna go with it
Old Aug 30, 2008 | 12:15 AM
labtec2's Avatar
Default Re: should i do b18c5 turbo or high compression (hondaekr)
so youve got two posts one is asking for greddy turbo psi on an ls and this one says you cant decide between NA and boost on a c5
building 2 cars?
for the greddy psi. 9-10lbs is what your map sensor can read
and for the second.
id personaly like to see a type r with a snail buuuut i think NA would be a better way since its like 9.5:1 ( i think...i dunno you search) already
Old Aug 31, 2008 | 05:35 PM
EkFG's Avatar
Default Re: should i do b18c5 turbo or high compression (labtec2)
be like me and build high comp with BOOST>>>
11.3: with boost
Old Aug 31, 2008 | 07:56 PM
1988_96hb's Avatar
if your using the b18c5 tranny id go with all motor but boost if not
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by labtec2 &raquo;</TD></TR><TR><TD CLASS="quote">building 2 cars?
</TD></TR></TABLE> hey theres nothing wrong with that
Old Aug 31, 2008 | 09:26 PM
hondaekr's Avatar
yea i got a itr tranny also
jdjustme
Mar 9, 2007 01:05 PM
vtec25
Jun 5, 2006 12:30 AM
ctr32
Feb 15, 2004 07:37 PM
SexyH22
Oct 2, 2003 05:59 PM
