rear disc brake swap problem
Old Aug 29, 2008 | 05:58 PM
hammergunner's Avatar
Default rear disc brake swap problem
i did the rear disc brake swap on my 91 EF
and the wheels sit inward really bad
so im wondering why its doing that?
i took the brakes off a 93 GSR integra
But the bar that controls the angle of the wheels it was the same size as the stock one on the drum brakes.
SOOOO it is the same why is the wheels sitting in ward.
Old Aug 29, 2008 | 07:12 PM
Ermil's Avatar
Default Re: rear disc brake swap problem (hammergunner)
You need to use EF compensator arms.
Old Aug 29, 2008 | 07:25 PM
Default Re: rear disc brake swap problem (Ermil)
you mean the little bars in front of the disc brakes?
if so, those were the same as the stock drum ones
Old Aug 29, 2008 | 07:28 PM
dispocrx's Avatar
the ones u need to change are the toe adjustment arms, the forward most arm on the control-arm that bolts up behind the gas tank...keep ur stock arms...
or u might need an alignment real bad, shouldve been a clean mark if u removed the whole arm already...
Old Aug 29, 2008 | 07:49 PM
Default Re: (dispocrx)
could you show me where its at please?
classdork987654
Apr 18, 2009 05:27 AM
classdork987654
Apr 1, 2009 02:56 PM
qat727
Dec 14, 2006 07:59 PM
whole9
Apr 28, 2006 05:58 PM
1991EFBeater
May 12, 2004 12:05 PM
