Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Weird Question - Rubber Gaskets
Old Aug 29, 2008 | 12:24 PM
ChargedSI's Avatar
Default Weird Question - Rubber Gaskets
Ok, this is weird question, but with all the knowledge on this site, I am hoping someone can answer this question.
Does anyone know what type of rubber Honda uses for the gasket that sits between the trunk-lid and the rear spooler?
If not, does anyone have any suggestions on what type of rubber I should get to make these gaskets?
Btw, I don't need this particular gasket, I am installing a different spooler and need to make a larger gasket for the application.
Thanks
Old Aug 31, 2008 | 07:18 PM
vladd's Avatar
Default Re: Weird Question - Rubber Gaskets (ChargedSI)
can't you just use double-sided tape?
Old Sep 1, 2008 | 11:27 AM
2008fijibluesi's Avatar
Default Re: Weird Question - Rubber Gaskets (vladd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vladd &raquo;</TD></TR><TR><TD CLASS="quote">can't you just use double-sided tape?</TD></TR></TABLE>
Yes, but I think he is asking for the gaskets for a waterproofing purpose. Maybe?
OP, I don't know if this helps but I found the part online. I tried to link a site but it won't work. Maybe you could call Honda with the part number and ask them? This is the best I could do with my research.
There were three part numbers (one for each seal; left, center and right)
left seal 71712-SVB-A00
center seal 71713-SVB-A00
right seal 71711-SVB-A00
*All of these part numbers are for a 2007 FG2*
Old Sep 1, 2008 | 11:29 AM
vladd's Avatar
Default Re: Weird Question - Rubber Gaskets (2008fijibluesi)
i've used 3m double sided tape to put emblems on, it's made out of rubber. i'm pretty sure it's waterproof. i got it from schuck's.
Old Sep 1, 2008 | 11:51 AM
I've used it before helping someone install a bodykit. I didn't examine the package too much, but I'm not sure it's completely waterproof, although I could be wrong. I know that water won't break it down, but I'm not sure if it will prevent the water from leaking into the trunk.
Old Sep 4, 2008 | 01:48 PM
ChargedSI's Avatar
Thanks for all the responses.
Yes, I want a gasket between the spooler and trunk-lid for water proofing and vibration.
Factory gasket will not work, the spooler I am putting on is the JDM-R Style Spooler. It has a larger foot print on the trunk-lid.
I did a little more research and found a couple materials that will work, but I think I am just going to try using 1/16 inch Neopreme rubber.
Btw, if any of you buy this spooler, expect to spend a lot of time filling and sanding the thing. The product from the factory is not the best out of the box.
Modified by ChargedSI at 3:05 PM 9/4/2008
Modified by ChargedSI at 3:06 PM 9/4/2008
miguey310
Mar 9, 2011 06:53 PM
cfwthb_94
Aug 17, 2009 07:48 PM
new2thegame
Jun 20, 2007 11:36 AM
ondahush
Jan 10, 2006 06:46 AM
civicnar
10
Mar 12, 2004 05:52 AM
