Need paint for touch up
Old Aug 29, 2008 | 07:29 AM
shadowBunny's Avatar
Default Need paint for touch up
Hi all,
I'm looking for information on how to get some paint for our 93 del Sol in samba green I believe. Are there any places online to order it?
Thanks,
sb
Old Aug 30, 2008 | 06:20 AM
De_tour's Avatar
Default Re: Need paint for touch up (shadowBunny)
http://www.automotivetouchup.com/
Old Aug 30, 2008 | 06:41 AM
BlackDeuceCoupe's Avatar
HT White Ops
Default Re: Need paint for touch up (De_tour)
Hrm...
My ride is Vogue Silver Metallic, but...
I noticed that on that web site - VSM comes in NH583M-2 , NH583M-4, and NH583M-5.
Sup dat? Different shades? Different countries?
Old Aug 30, 2008 | 07:16 AM
De_tour's Avatar
Default Re: Need paint for touch up (BlackDeuceCoupe)
I would say either shade or metallic
Old Aug 30, 2008 | 07:31 AM
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by De_tour &raquo;</TD></TR><TR><TD CLASS="quote">I would say either shade or metallic</TD></TR></TABLE>
Well...
It would be a bish touching up your paint with the wrong "shade or metallic", no?!?!?
I noticed almost all of the (older) Honda colors are listed this way...
Old Aug 30, 2008 | 07:40 AM
HT White Ops
Aha!
This is probably why I've never seen VSM touch-up paint in a Pep Boys or whatever!
There's 3 different Vogue Silver Metallics...
SOURCE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Special note on Honda and Acura.
The factory code is located in the lower right hand corner of your color tag. (The color tag is usually located on the drivers door jamb, but if you don't see it, take a look on the passenger side door jamb.) For example, the color below would be listed on our site as B-89P. When you select factory code A from the drop down list of factory codes on our site, the color code becomes B-89-A which is not the same color as B-89. For accurate colors, please enter this letter or number! If you do not see a factory code on your color tag, please use the 11th digit of your VIN.
Many Honda and Acura vehicles will not have a factory code. Again, enter the 11th digit of your VIN so we can properly formulate your paint. If you have a factory code and it does not match the 11th digit of your VIN, use the factory code on your color tag.
Please note!
On some color tags the factory designation is part of the color code. For example, if your paint code reads B-89P-3, then the -3 is your factory code and MUST be entered in the factory code box on the order form.</TD></TR></TABLE>
The 11th digit on my VIN is 'L', so that doesn't tell me jack!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackDeuceCoupe &raquo;</TD></TR><TR><TD CLASS="quote">My ride is Vogue Silver Metallic, but...
I noticed that on that web site - VSM comes in NH583M-2 , NH583M-4, and NH583M-5.</TD></TR></TABLE>
Old Aug 30, 2008 | 08:11 AM
BuiltforSin's Avatar
Touch up paint is like $14.25 at Honda. The exterior color code is on your drivers side door jamb. By the door chuck.
Old Aug 30, 2008 | 09:53 AM
HT White Ops
Default Re: Need paint for touch up (Eran)
Door jam sticker says NH583M - Factory code/11th digit is 'L'. Hence, 'NH583M-L'.
The three choices are: NH583M-2 , NH583M-4, and NH583M-5
Modified by Padawan at 3:34 PM 8/30/2008
Old Aug 30, 2008 | 11:34 AM
Eran's Avatar
HT White Ops
Then pick a different site like PaintScratch.com
http://www.paintscratch.com/cgi-bin/makepaint2.cgi
What you have is original VSM, not a batch color. That's what 2, 4, and 5 are. They're second runs of the original batch.
And that didn't take an edit. I edited the 're: BlackDeuceCoupe' in so the OP didn't think I was talking to him.
Old Aug 30, 2008 | 11:41 AM
SuperSonikBluEK's Avatar
Default Re: (Eran)
just get the number code off the driver side door jam and take the code to your local auto paint store and they will make and mix the paint for you! simple as that!
h22swapedsol
Sep 8, 2007 01:12 PM
kelviiv
Paint and Body
Jul 4, 2007 01:49 AM
jit01
Mar 18, 2007 07:17 AM
O16581724 5 2 5
Oct 12, 2005 11:22 PM
Blazeone
May 30, 2003 08:18 AM
