Need Help to decide on my piston setup. Stock or 12:1cr???
I just recently refreshed my ITR b18c5 bottom end.
Stock USDM ITR pistons 10.8:1cr??
ACL bearings
balanced and polished rods
balanced pistons and polished crank
New OEM ITR oilpump, tensioner and water pump
The head is fully built with a gasket match. (the port is slightly larger than gasket to be exact)
5 angle valve job
1mm oversized Ferrea Valves, Valvesprings, valve seats and valve guides, felpro valvestem seals.
Supertech retainers
Skunk2 Pro 1 cams
The head's been milled twice.
Edelbrock Victor X, 70mm w/ adaptor plate, ported to match intake ports on head
Now im wondering if I should order some 12:1cr pistons or should I just keep the stock OEM 10.8:1cr pistons? Would the 12:1cr pistons make much difference? My friend says it doesn't. But my other buddy says it does. So WTF, you know. So should I spend an extra $500 just for the 12:1cr pistons?
ACL bearings
5 angle valve job
Supertech retainers
Skunk2 Pro 1 cams
The thing is that I already had the whole block assembled and now I'll have to pay another 200 just to have the shop change it out. I was thinking about the 12:cr but one of my buddy says not to waste money and just go with what i have. :/
b20powereDA
Jun 21, 2007 04:40 PM
ITR.#1446
Jun 7, 2005 12:47 PM
